slicks..
Old Feb 18, 2008 | 08:56 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
slicks..
want something about 27 inchs tall and about 10 inchs of tread. hoosier qt's or mickey thompson et streets? what are you guys using?
Old Feb 19, 2008 | 12:38 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: slicks..
qtp over et street
Old Feb 19, 2008 | 01:09 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: slicks..
i know hoosier makes a 27 inch tall tire, i'm not sure about m/t. I know ET streets have a 26.2 inch tall tire on some of the wider 26inch models...i dont know what slicks they offer. 27 seems like an odd size
Old Feb 19, 2008 | 06:09 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: slicks..
so hoosiers will hook for me?
Old Feb 19, 2008 | 06:17 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: slicks..
http://cgi.ebay.com/ebaymotors/HOOSI...spagenameZWDVW
i was looking for something like these.
Old Feb 19, 2008 | 07:33 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: slicks..
I am using the 26" Hoosier QTP's and pulled both front wheels about 2". I am getting 1.63 60ft times. Thats without sfc's.
Check out WWW.harlowracing.com
They can set you up with the right set. They also match the roll out unlike some other companys. They have good prices and the shipping is cheap.
Old Feb 19, 2008 | 02:24 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: slicks..
your a brave man for racing without sfc's. lol i have gone 1.52 on my radials but its not consistent. i want to be able to shove my foot to the floor and go. dont think i will be able to do that without slicks.
Old Feb 19, 2008 | 06:15 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: slicks..
If you still need DOT the hoosier QTP`s...I went 1.4`s on a 29x11.5x15 have been 9.8`s on them, got 70-80 solid runs on them too
Old Feb 22, 2008 | 06:10 PM
TBI89Formula's Avatar
Re: slicks..
Mickey makes a 27.1" tall ET Street Radial with 10.7" section width and 8.8" of tread width; its part number 3756R (255/60R15). If you have a 15" rim and want a radial that will be the closest thing they have to the size you want. Mickey also offers a Bias-Ply ET Street in a simmilar size (part number 3758) but I imagine the radial will be faster on your application. Both are DOT approved. http://www.mickeythompsontires.com
Old Feb 25, 2008 | 10:24 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: slicks..
will an et drag 28x11.5 fit my car on a 15x10 with a 5.5 inch backspace. i already had 325/50/15 mickeys on.
Old Feb 25, 2008 | 10:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: slicks..
Maybe.
ET drag tire width is measured across the tread so an 11.5 will have an even wider section width. I squeezed a 29.5 x 10.5 on 15 x 10 rims with 5.5" of backspace under my fenders but needed to do some inner fender modifications. Dropping down to a 28" tall tire may allow a little more room at the front of the fender but that's still a very wide tire. A 28 x 10.5 ET drag will probably fit with no problems or with only minor modifications.
DOT tire width is measured across the section so the tread will always be less than the rated width.
Old Feb 29, 2008 | 09:09 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: slicks..
i think im just gonna order a set of 27/11.5/15 hoosier qtp's and get rid of my 275/50 mickeys, that way i dont have to buy another set of wheels and i can just put them on my 15x8s.
Old Mar 1, 2008 | 08:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: slicks..
sounds like a good plan to me
toolegit86
Mar 28, 2011 11:31 PM
91interceptorZ
Exterior Parts for Sale
Apr 28, 2009 09:55 AM
Alan84TA
May 23, 2002 08:10 AM
