Steering Stabilizer??
Old Mar 17, 2008 | 09:13 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
I was just wondering if anybody made a steering stabilizer kit for f-body's. I dont think anything crazy like the dual shock setups on the 4x4's would be necessary, but a good single one would probably make driving alot smoother.
I thought about trying to fab something up for fun, but I would have to adapt one off of a truck or something. A regular shock wouldnt work, because the rebound would run you off the road. I would need dampening, but no rebound.
Also, how much harder to turn the wheel would it be? I have the quick-ratio steering already, so it is a b***h to try and steer while drinking to something. At least a damper would keep the car from wandering soo much all the time though, over every little bump.
Oh yeah, I already read about the "ed quay" one, but that seems more for drag racing / highly modded cars. And needs welding.
I would want one to help out daily driving, on crap roads and grooved highways. I dont plan on doing wheelies any time soon!
Last edited by slow_90firebird; Mar 17, 2008 at 09:15 PM. Reason: Automerged Doublepost
Old Jan 29, 2010 | 11:20 PM
twigger's Avatar
Car: '91-Z28/'03 Honda 919
Axle/Gears: '99 Zexel 3.42
Re: Steering Stabilizer??
Hey just looking for a little better feel for the road at higher speeds. Has anyone tried a stabilizer for this application yet?? Or does the power steering making this a useless attempt?
Old Feb 2, 2010 | 12:40 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pondering On The Wandering
If it’s wandering over bumps, etc, you probably have worn steering and/or suspension parts which can happen in a short amount of time based on the type of roads you mentioned.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 2, 2010 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Pondering On The Wandering
could also be experiencing bumpsteer, or the effects of dead shocks and struts
Old Feb 3, 2010 | 08:28 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
i wouldnt think a stabilizer like you are thinking of would work on a IFS car, thye are for solid axles. on a solid axle thye are helpful because the whole axle can shift back and forth within bushing tolerances and the steering also shifts back and forth. but you dont even need it on a solid axle if everyhting is "new car" tight
Old Feb 4, 2010 | 02:18 AM
twigger's Avatar
Maybe so but I am going through all my steering and replacing to get it as good as new if not better. I had a couple 80s era Supras which are IFS with rack and pinion steering and those use a damper right there on the rack. Very solid feel with those at any speed. On the Camaro with tight steering new tires and lots of caster it feels a little too twitchy for my liking. Just hoping someone who has tried it might be able to offer some input.
Old Feb 4, 2010 | 08:58 AM
stealtht/a's Avatar
interesting. do you know where the stabilizer attaches on these supras? is it a damper from the tie rod to the chassis?
Old Feb 4, 2010 | 10:22 AM
Guest
Guest
Posts: n/a
You do not need a steering stabilize on these cars unless you are lifting the front whels and sitting them back down at an increased speed that wwill wobble the steering wheel...You pulling wheelies?
Ops, my bad, I read the bottom of your post where you say you do not plan on any wheelies soon.
But seriously...no, you do not use a stabilizer to correct poor alingment, bumpsteer, or worn componants....or any combination of the three.
Old Feb 4, 2010 | 05:55 PM
Campbell84'T/A's Avatar
cheepest way to get some good road feel is to set the caster more positive, this wont wear your tires any faster and you will get better road feel, but not just at high speeds, it will be all the time
Old Feb 18, 2010 | 03:07 AM
twigger's Avatar
Better reread I pop wheelies all the time, just not with my car.
I have chrome moly swaybars with polyurethane bushings, new shocks, Eibach springs and all new wheel bearings, new Moog everything, new Redhead Steering Gear, new GM original steering shaft. Alignment for both sides is roughly 4.8 degrees caster, 0 degrees toe and camber. Steering is tight as it gets but it is still not what I am looking for. This car should not be so twitchy, I feel like I could sneeze and end up turning a 180 on the highway!
Maybe I need to look at the powersteering pump and possibly lower the pump output pressure to firm it up a little, think that might help?
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
