cracking sound
Old Mar 18, 2008 | 10:04 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
cracking sound
hi when i turn my steering wheel all the way to the left i hear a cracking sound. like something is broken. a quick look under doesn't show anything hanging or visually broken. what can this be?
Old Mar 19, 2008 | 11:07 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Re: cracking sound
Take a good look at the steering linkage. You probably have some bushings or joints that are worn out and need to be replaced.
Old Mar 20, 2008 | 07:57 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
Re: cracking sound
such as the steering rach, inner and out tie rods? to replace the front shocks do i have to remove the rotor?
Old Mar 20, 2008 | 08:33 PM
Pukka's Avatar
Re: cracking sound
All of your tie rod connections, your idler arm and pitman arm should be checked. Basically wherever there is rubber. Check out the sticky on steering suspension - it has a very good diagram.
Not sure if you have to remove the rotors to replace the front shocks.
92firebirdguy
Sep 1, 2016 07:53 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
cstrobel65
Sep 16, 2015 11:54 AM
Blue419
Sep 10, 2015 01:03 PM
