Boxed LCA?
Old Mar 28, 2008 | 09:41 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Boxed LCA?
I'm thinking about boxing my lca and was wondering if there are any big benefits of the aftermarket pieces? Are they lighter or alot stiffer? The car is a basicly stock GTA that is getting alot of wheel hop. I have Tokico springs(1" drop) and matched shocks that I will be installing soon. And I also have Comp Eng sfc that i'll be installing next weak end.
Old Mar 29, 2008 | 12:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Boxed LCA?
If you box your arms, they will be stiff enought, but will end up a little heavyer than the aftermarket ones. Are you using poly bushings or stock rubber?
Old Mar 29, 2008 | 06:22 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Boxed LCA?
If wheel hop is your problem, get a set of LCA relocation brackets.
Old Mar 30, 2008 | 12:29 AM
bgood71's Avatar
Car: 89 GTA
Re: Boxed LCA?
Right now the suspension is completely stock. As I mentioned, I do have SFCs and 1"drop springs and matching shocks that aren't installed yet.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
