issues!!
Old Apr 6, 2008 | 08:57 PM
speedped79's Avatar
Car: 1982 z28
issues!!
ok its a 91 camaro, it always had play in the front but i didnt care to fix it because i didnt have the $ now i do. i recently added soem 18 in wheels but they all needed spacers but i added 1in spacers to the fronts so they fit and didnt get them for the rear yet so the fronts wider then the back. once i added the front rims with spacers it got bad, so i decided hell lets fix it, so i got new tie rods ends, got it aligned and there was still play in it, so i got a new center link and idler arm, now its alot stiffer feeling, but still some play(im thinking steering box) but it wonders alot still and will occasionally pull and the wheels alignment is off again dude to the centerlink and idler arm replacement, so my question is the front being wider making it handle bad? or should i get it aligned again and go from there? i have to get 1/2 in spacers for the rear anyway so should i order these before the alignment? i mean it drives good and straight just the wheels turned a little
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
