4th gen struts in a third gen
Old Apr 24, 2008 | 04:41 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
I heard this could be done to put ls1 brakes on the front anyone done this?
Is it really possable?
What kind of mods are needed?
Or is it better to use Ed Millers Adapters.
Old Apr 24, 2008 | 05:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen struts in a third gen
No need to mess with struts.
JamesC
Old Apr 24, 2008 | 07:26 AM
tshack's Avatar
Car: 87 Z28
Axle/Gears: 3:43
I should of said spindles ,hubs & brakes
Old Apr 24, 2008 | 07:46 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
It's possible to DYI, and from what I've read it's not really that hard. Just can't remember exacty what's required.
Old Apr 27, 2008 | 04:02 AM
tshack's Avatar
Car: 87 Z28
Axle/Gears: 3:43
Any one else know where I can find directions, Or a write up on doing this.
It seems to me if i went this route, over modifing stock spindels & adding brackets. I could use 4th gen rims with out spacers. could be wrong though it's happened before
Old Apr 27, 2008 | 10:05 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
??? What? How would you get 4th gen spindles to work on a thirdgen? Completely different front suspension set up. Thirdgen uses a strut... 4th gen uses dual a-arms and coil overs.
I cant see this being done without welding on the spindle...which is a pain.
If you are just wanting to run LS1 brakes, you are way better off just using one of Ed's kits...or bigbrakeupgrade...or fabbing your own. Way less work and messing around. If you want to run LS1 wheels as well, adapters from Skulte would be my recommendation. Thats what I run and they are great.
Ive never heard of anyone making anything from the front end of a 4th gen work...but, Ive been wrong before. Atleast a couple times. So...if there is info for this out there, post up.
J.
Old Apr 27, 2008 | 11:03 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
not going to happen inless you pull a Fatal88
Old Apr 28, 2008 | 12:03 AM
Car: 86 Trans AM
Yeah I meant to mention that...could do it if you swapped in most of the front end of a 4th gen...like fatal.
J.
Frozer!!!
Jan 19, 2024 04:55 PM
cam-mike
Aug 24, 2015 07:23 AM
