best adapter size for 4th gen ws6 wheel
Old Apr 24, 2008 | 09:48 AM
jrs84ta's Avatar
Car: 1984 firebird
Engine: swapping lt1
i got some 17 by 9 ws6 rims the other day and need to know whats the best size adapter for these rims to fit without them alot sticking out. I've heard 1.5 or 2" which would work
Old Apr 24, 2008 | 10:36 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: best adapter size for 4th gen ws6 wheel
The best size adapter/spacer would depend on the backspacing on your wheels.
I recomend www.skulte.com. He knows this stuff and is a member here. But he will need to know the backspacing.
Old Apr 24, 2008 | 04:51 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
before I got my 4th gen rear, I ran 2" spacers all around, with ls1 brakes on all corners. This is how far they stuck out. I might end up getting new spacers one day, at 1.7 or possibly 1.5 inches up front. My advice, go with 1.7" spacers.
Old Apr 24, 2008 | 10:28 PM
jrs84ta's Avatar
Car: 1984 firebird
so there wouldn't be a problem with the 1.7" up front, i know it will clear on the rears. I'm going to check the back space tomorrow just want to get it right before i order any.
And thanks for the info.
Old Apr 24, 2008 | 10:47 PM
krisb410's Avatar
That's the only way you'll know for sure.
Old Apr 27, 2008 | 01:23 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I ran 1.25" ones up front with my '02 thick spoke 17x9 WS6 wheels. I also have LS1 brakes which space it out 1/8" or so. They tucked awesome up front. For the rear I had a 4th gen rearend.
Old Apr 27, 2008 | 02:09 PM
jrs84ta's Avatar
Car: 1984 firebird
those are the ones i have. i went a head and got 2" adapters if i dont like it i will go smaller later.
Old Apr 27, 2008 | 09:56 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
With stock 3rd gen brakes, should be 2" all the way around. With LS1 brakes up front, should be 1.7". Im running LS1 brakes, and a 4th gen 12bolt...So I got 1.7" in the front, and nothing in the rear. And they are perfect.
X2 on Skulte. Andres is a great guy, knows his stuff, and is willing to help you out.
J.
1992rs/ss
16
Jan 28, 2016 09:58 PM
toronto formula
Nov 10, 2015 06:17 AM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
knight72
Aug 10, 2015 09:32 PM
