C5 Wheels on 91 Camaro... need spacer info??
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
Before I get razzed, I looked at the stickey's..........
I have a buddy who has traded me a very nice set of C5 ZO6 wheels (aftermarket) for some stuff I had from my vette. I want to put them on my 91 RS and was just wanting to know the exact size spacer I will need. I believe it's the same as if I wanted to run 93+ Camaro rims correct?? (dont know that either though)
So what size spacer will fit the 17" wheels I got?
Car: 1991 Camaro
Transmission: TH350
Re: C5 Wheels on 91 Camaro... need spacer info??
Here's the specs on the rims to help out...
17x9.5
56mm bs?
17x9.5
56mm bs?
Car: 1991 Camaro
Transmission: TH350
Can a guy get some help here???
Car: 1991 Camaro
Transmission: TH350
All I found were posts of guys running different sizes, some are like 2" front and 1 1/4" rear??
I was confused, so thought I would ask. Will the wheels sit inside the wheel wells or will they stick out and look like a$$ ??
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I have a 4th gen rear and 2 inch spacers. I don't think I'd want 2.25s on the front (at least not on my car). I think it would stick out too much. Take a look at mine if you want. (click on sig pic)
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
