Will 93 up rims work on my 91?
Old May 5, 2008 | 09:43 AM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
2 17x8.5 and 2 18x9.5 will these fit on my 91 without real hard modifications? They are off a corvette but they said they will fit 93 newer camaro.
Old May 5, 2008 | 09:59 AM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
Re: Will 93 up rims work on my 91?
im not sure about the sizes and whatnot, but i am posotive you will have to buy adapters.
Old May 5, 2008 | 10:30 AM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
I used to run Corvette Wagon wheels from an older C5 Vette and they are the same back spacing as 4th Gen Camaro wheels. You'll most likely need 1.5 inch Adapters all around in order to run those wheels!
Old May 5, 2008 | 11:27 AM
92WhiteZ28's Avatar
Old May 5, 2008 | 09:59 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
By adapters you mean spacers right? So Ill need 1.5 inch thick spacers to make them fit?
Old May 6, 2008 | 11:39 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I had to use 2 1/4" spacer up front with my ZR1's, 17x9.5 with +56mm backspacing, and 2" spacers in the rear. The width of the adapter will depend on your backspacing on the wheels you have. I highly recommend www.skulte.com he is a member on here and knows wheel fitment
Old May 6, 2008 | 09:50 PM
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Thank you very much.
Old May 11, 2008 | 02:37 PM
billyhoss's Avatar
i have a set of 96 rims on my 91 and i had to get a set of 2" spacers and they fit perfect, go with the 2"
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
