Running Dual Subframe Connectors
Car: 91redTA
I've searched the boards and found no info.
Has anyone run both Alston style and Spohn style subframe connectors at the same time?
I believe the Spohn are perimeter and the Alston are placed more down the centerline. Most likely there would be small adjustments needed to run both.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: Running Dual Subframe Connectors
Seriously no offense, but search harder.
This has been done many many many times.
I have read about it for at least a couple years now. There is almost no issues running both. Added weight, but def ties the car togeahter nicely.
I have hotchkis SFC and an an 8 point cage. SUPER rigid.
Cost, about $350 for eveything. self installed.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
if your already plainng on runnig 2 sets why not run one and a cage.... its almost pointless to run 2 set of subframes
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
I think he is obviously going for something more structural so the cage would be beneficial
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Running two sets of SFCs is hardly pointless. Especially since the two particular sets mentioned work in two different areas. The more reinforcement you give to the unibody the better. My car had spohn bars and they were great with my TPI setup...but the LS1 set up was causing some body movement
Plus...a cage isnt that great for the street. If he's running the car on the street 95% of the time, whats the point of a cage? Plus, cant put people/kids in the back seat with a cage, and it makes working on the interior a bit of a pain. Cages are for people that are running quick enough to get kicked out of the track without one. Chassis reinforcement is for street cars that need some stiffening.
Just my $.02....
J.
Just my $.02....
J.
Car: 1983 Z28
Engine: 355
anybody have pics of the alstons along side the spohns? cant really find a good one of the alstons installed especially in the front of the car. any pics would be helpful if you have them. the underside of my car looks like it has been dragged and banged up pretty good and i'm having a tough time lining up the front driver side sfc.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
yes i wanna see pics of this dual subframing.
i installed my own design of thru floor subframe of 2"x2" square steel tubing i think it was .095" thickness and i cut into the front and rear subframe as well as the floor and ran it right into them and welded it completly. really stiffened up the car but i just also installed a 6pt comp engineering cage but i want to run a 1"x1"x.095" thick perimeter subfram just to tie it up alil better. i havent driven the car with the 6pt cage yet since the car is just a shell. car will be a daily driver too
how about 2 sets of subframes inboard and perimeter and a cage!!! plus cages just look badass. sports cars dont need passengers ;P
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
I have alstons and jegster SFC's on my car... in my exhaust pics u can see them
Car: 87 TA clone
hmm i see i see. i was thinking of the jegsters but there just alil too pricey for me...
i have the same exhaust but mines 3" mandrel bent... i had crush bent pipes like yours before my new setup and the mandrel made a huge diff.
also did u notice a diff with the jegster tq arm? i just intalled mine but its the non adjustable one. bolted mine to my 6 pt cage too to stiffen that up :P
Car: 1983 trans am
the only thing i have to compare it to is a stock tq arm so yes it is much better than stock... with my et streets i have no traction problems on the street
Car: 87 TA clone
ok thats what i want to hear. thats wat im upgrading from... the stocker with a poly bushing. what did u set pinon angle to??
Car: 1983 trans am
honestly i don't have an angle finder and and i just adjustd it so that it looked like it was slightly angled down and it seems fine. i know its not the right way to do it.....
MaNiAk86,
Can u post up some more pictures of ur torq arm ? looks like thats the way to go to run tru duals with a X-pipe......I am asuming that exhaust setup is not possible with stock torq arms or any other aftermarket Torq arms
Car: 1983 trans am
its just a jegster tunnel mount adj. tq arm i bought used off a fellow member here. i think any tunnel mounted setup should leave some room to run an x after the trans x-member
eightsixseven
Dec 16, 2024 01:50 PM
1984, camaro, chassis, connectors, frame, gen, install, installing, jegster, pics, pictures, subframe, subframing
