Front sway bar install, did I do something wrong?
Old Aug 13, 2008 | 02:58 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I purchased Spohn Front & Rear sway bars, along with a panhard bar. Rear sway bar and panhard went in perfect. The car has Prokit springs.
For the front sway bar I:
1) Removed old one (which had a bracket attached to it with another bar on top of it, is this the wonderbar?)
2) Put this bracket and bar on the new sway bar
3) Attached the brackets first to new sway bar, THEN did the end links.
4) While the car was on jack stands, I tightened everything down (end links last).
When I was done, my driver side tire was hanging lower then the passenger side (car still on jack stands). When I lowered it to the ground, my wheel gap was higher in the front than before. Also, the driver side wheel gap was larger than the passenger side.
I took it for a drive, and it handled AWESOME. After a 10 minute drive, my wheel gap in the front went down to where it was before, and both sides were even again.
Do you think I'm ok? Anything I should check? Thanks guys!
Old Aug 13, 2008 | 07:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front sway bar install, did I do something wrong?
Wonderbar. Sounds normal to me.
JamesC
Old Aug 13, 2008 | 11:57 AM
Car: 1988 IROC-Z
Engine: 427 SBC
JamesC
Great! Thanks James! Do you think I'd see any difference by removing the stock wonderbar and putting a Spohn one in? That stock sway bar is light! My aftermarket one is much heavier.
Old Aug 13, 2008 | 12:17 PM
JamesC's Avatar
No.
I do get a chuckle out of members who swap in a Wonderbar and proclaim what a difference it makes in handling and how they can feel that difference--and maybe it does make a difference if the steering box area is cracked to heck--but in a blind test, few, if any, would be able to tell whether their car was equipped with the brace or not. GM designed the darned thing as a Bandaid and in the last few years it's become a performance piece in the minds of many members.
JamesC
Old Aug 13, 2008 | 09:59 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Your supposed to torque everything down when the weight of the vehicle is on it.
In a way the wonderbar is a performance part. Like you said, it prevents the frame around the steering box from cracking. This means it strengthens that area of the car, and the extra strength will prevent future cracking. Therefor preserving the high performance aspect of our vehicles, making it a performance piece. So yes, it is a performance piece, and don't even get me started on the performance aspect of the adjustable wonderbar...
Mike
Old Aug 13, 2008 | 10:08 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
The stock sway bar is lighter than the Spohn one?
Old Aug 14, 2008 | 01:17 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Mike
I read my manual, it says to do it when its on jackstands. I did a search here, and it seems people do both. Kind of confused there.
Yes, by quite a bit.
Old Aug 14, 2008 | 06:52 AM
JamesC's Avatar
We'll have to agree to disagree about the Wonderbar's performance properties. At any rate, we're off topic.
I torqued up on stands as the manual indicates.
JamesC
Old Aug 14, 2008 | 12:04 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks for all the replies guys! I emailed Spohn and his response was:
"You need to tighten the end links with the suspension loaded. Tighten them until the bushings start to compress and then stop."
Old Aug 14, 2008 | 12:10 PM
JamesC's Avatar
Another manufacturer suggested torquing, then driving a few miles before double checking. Seems reasonable.
JamesC
Old Aug 14, 2008 | 11:46 PM
Car: 1987 IROC-Z
Transmission: TH350
You didn't happen to ask him about the bushings did you? It would be kind of nice to know what they say should be done with those as well.
I have always torqued everything with the weight of the vehicle on the suspension, and then drove around a little and re-torqued everything but it never needed to be re-torqued.
Old Aug 17, 2008 | 11:36 AM
lonesomecrow's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
No.
JamesC
That is why I am so happy with my $15 stocker from a donor at the local P'NP
Old Aug 21, 2008 | 02:03 AM
FireTurdWS626's Avatar
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
[quote=IROCThe5.7L;3857003]I read my manual, it says to do it when its on jackstands. I did a search here, and it seems people do both. Kind of confused there.
well if your torque all the parts down in the air, when you drop the car you will twist or rip your bushins, and i know u don't want that
Old Sep 7, 2013 | 09:40 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
This might sound like a dumb question, but after installing the brackets on the sway bar, how do you put the weight back on the suspension with the wheels being off? Can the endlinks be tightened down with the wheels back on?
Old Sep 7, 2013 | 09:50 AM
All of that "suspension loaded" stuff doesn't apply to sway bar parts. Just put em on, and tighten the bushings down to around 40 ft-lbs, and the links until the rubber is just barely larger than the washers.
Old Sep 7, 2013 | 11:32 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Thanks sofa, that info is going to help me alot when i replace the front sway bar next week!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
evilstuie
Jan 9, 2020 08:29 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
