Wheel Bearing replacement
Old Oct 22, 2008 | 10:14 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
So my wheel bearings have started grinding and need replacement.
Was planning on doing that tomorrow, but I need to make sure I get the right parts.
I know I need inner and outer bearings. What kind of seal do I need?
Is this the correct seal? http://www.partsamerica.com/ProductD...pe=292&PTSet=A
Do I need just one seal per wheel or two?
Also, do I need the special tools? I see directions using special tools, and then directions not using special tools.
Buff
Old Oct 22, 2008 | 10:26 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Wheel Bearing replacement
It should be called an inner wheel seal, that pic looks like what it is. Only one seal per tire. Only thing that comes to mind is there might be a large torq or allen to take the calipers off.
Pull tire and calipers
remove dust cap
take out cotter pin, nut, and outer bearing
rotor will slide off with rear bearing and seal
yank that seal and rear bearing out
put new packed rear bearing in and tap in the seal, and put all back together.
Old Oct 23, 2008 | 02:04 PM
Engine: 2.8L - 6.3L
What about the races?
The passenger side inner race seems worn, think it should be replaced.
Manual says take it to a machine shop. That the only way?
Old Oct 23, 2008 | 02:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
New bearings come with new races.
JamesC
Old Oct 23, 2008 | 02:12 PM
Engine: 2.8L - 6.3L
well my question is wether the races can be popped out by me.
The manual says to take it to a machine shop to have the races replaced.
Old Oct 23, 2008 | 02:18 PM
JamesC's Avatar
Sure. Drive the old out with something, perhaps a brass drift, then drive the new back in. Use a north, south, east, west driving configuration.
JamesC
Old Oct 23, 2008 | 02:23 PM
Engine: 2.8L - 6.3L
thanks
Old Jan 10, 2009 | 07:20 PM
dj_justice's Avatar
Car: 91 Formula Firebird
Transmission: 4l60
Anybody know what size the spindle lock nut is? My wheel bearing went bad and the nut is on really tight.
Old Jan 10, 2009 | 08:27 PM
JamesC's Avatar
Put a socket on it and see. Actually, the nut is supposed to be hand tight (if not, that may be why the bearing went bad).
JamesC
Old Jan 11, 2009 | 09:07 AM
dj_justice's Avatar
Transmission: 4l60
Yeah well the largest socket i have is 24mm and its bigger than that. I was just wanted to know so i dont have to go buy a bunch of sockets i dont need.
Old Jan 11, 2009 | 09:21 AM
JamesC's Avatar
27 mm. Before buying anything, you might try a pair of channel locks, a pipe wrench, or an adjustable wrench.
JamesC
Old Jan 11, 2009 | 03:49 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Dumb question, but you did pull the cotter pin out, correct?
Old Jan 20, 2009 | 03:50 PM
dj_justice's Avatar
Transmission: 4l60
Yeah I pulled the pin out. It turns out the bearing broke into pieces and were welded to the spindle. So I ended up replacing the whole spindle.
Old Jan 20, 2009 | 04:30 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Old Jan 21, 2009 | 09:53 AM
kcb37's Avatar
Doesn't sound like anything you did at all but,
The lesson here is that sometimes knowing the proper torque spec's and putting it together (right or by the book) can keep your car on the road and not wrecked.
red90IROCls1
Aug 25, 2015 06:56 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
