global west control arms... no panhard rod?
Old Oct 29, 2008 | 12:21 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
"Global West's Super Duty rear lower control arms are designed to be factory replacement units. They are intended for applications that require the utmost in control. Drag racing, road racing, autocross, and street performance cars will benefit by using these Super Duty rear control arms. These control arms use spherical aircraft bearings and Del-a-lum bushings to control rear-end lateral movement, as well as fore and aft location. They allow for full rear-end articulation without bind and eliminate the need for a panhard rod."
I copied this from http://store.summitracing.com/partde...5&autoview=sku , Is it true that these eliminate the need of a panhard rod? Or, is this only for off road applications? my car is my daily driver...
Old Oct 29, 2008 | 06:03 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: global west control arms... no panhard rod?
No way, whats going to keep your rear from going side to side in cornering? Without the panhard i think the rear will just fall out of the car lol.
Maybe im wrong but i wouldnt even back my car out of the shed without it.
Old Oct 29, 2008 | 06:11 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
i agree, that's why i questioned it. It also seems like it would put a lot of stress on the control arm mounting points. It must only be made to go 1/4 mile at a time.
Old Oct 29, 2008 | 06:18 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i may be wrong but i just don't understand how they can replace the panhard bar . has anybody tried them ?
Old Oct 29, 2008 | 08:02 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I have those GW control arms in my car....
You still need a panhard rod - they are probably referring to not neding an aftermarket rod with their arms.
Old Oct 29, 2008 | 08:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its a typo or a line of bs
you need a panhard bar, end of story.
Old Oct 29, 2008 | 08:30 PM
hotpart's Avatar
You can eliminate the panhard rod with their control arms because of the bushing design. They put massive load on the chassis mounts and create an unbelievable amount of bind in the rear suspension because of the Delrin bushing on the chassis side. It is also that Delrin bushing which would eliminate side to side movement and therefore allowing the removal of the panhard rod. You can still use a panhard rod as long as you are using a panhard rod with soft rubber bushings. If you switched to a panhard rod with rod ends your suspension would probably lock up or tear some mounts.
Old Oct 29, 2008 | 08:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it doesnt sound like a good idea, whats to keep the control arm mounts from tearing with all that extra lateral load?
Old Oct 30, 2008 | 12:13 AM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
There's no way I would eliminate the panhard bar, how would you center the axle. Later.
Old Oct 30, 2008 | 12:54 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I can't believe that claim... If they were cheaper and I had an extra car, I wouldn't mind testing them out just for ***** and giggles.
Mike
Old Oct 30, 2008 | 12:59 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I smell a law suit
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
