wonderbars
Old Oct 29, 2008 | 02:09 PM
cabmustang's Avatar
wonderbars
Is one wonderbar better than the other? Such as the TDS one vs. the one from UMI, I know the TDS has one more bolt as a mounting point but which is better, or are there others better than these?
Old Oct 29, 2008 | 02:48 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: wonderbars
they all do the same basic function of tying the front together. one doesn't do it any better than the other i don't believe, i've never heard of any differences. There is an adjustable one i just heard of recently, but thats a whole different ball of wax.
Old Oct 30, 2008 | 12:17 AM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Re: wonderbars
Like he said , they all do the same, only diff. is usually price. Later.
Old Oct 30, 2008 | 01:01 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: wonderbars
It's pretty hard to **** up. Metal bar with plates+bolt holes on each end. I think the TDS one has 3 bolt holes on each side rather than 2 like the stock and other aftermarket, for what it's worth.
Old Oct 30, 2008 | 01:19 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: wonderbars
Honestly, if you know how to weld, and how to use a pencil, punch, hammer, square, drill, and tape measure, you can make it yourself. It isn't hard.
Old Oct 30, 2008 | 10:47 AM
UMI Performance's Avatar
Re: wonderbars
Hello,
Our Wonder bar is a direct bolt in and requires no welding cutting or grinding.
If you have any additional questions please ask and I will be glad to help.
Thank you!
Ryan
Old Oct 30, 2008 | 01:50 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: wonderbars
I've been wondering of late about just welding the wonder bar to the car....
Old Oct 31, 2008 | 01:21 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: wonderbars
And then if you have the dual fans, you'll never get them out again without breaking them off.
Can't get to the bolts with the wonderbar in. I put in LS1 fans, so I just broke 'em off. >.>
Old Oct 31, 2008 | 02:39 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: wonderbars
Oh. I hadn't considered that. My car only has the single fan. Thanks for the info though!
Old Nov 3, 2008 | 02:01 PM
cabmustang's Avatar
Re: wonderbars
so the extra mounting point offered on the TDS unit doesn't really help with strength or anything?
Old Nov 3, 2008 | 02:11 PM
Stephen's Avatar
Car: 87 GTA
Re: wonderbars
My GTA has dual fans & a wonder bar....I had no problem getting the stock fans off without touching the wonder bar.
I suspect the LS1fans were the problem. No clue on their mounting.
Old Nov 3, 2008 | 02:19 PM
Axle/Gears: 3.27 BW
Re: wonderbars
It was getting the duals off. I couldn't get a wrench in the recessed holes on the lower part without pulling the wonderbar, so I just broke the tabs off. Lazy yes, but also effective. Though I probably could have sold the fans on here....
As for strength on the TDS unit, I'm sure it adds strength, but I don't think you need it. The wonderbar and the k-member braces stopped all of the problems with these cars cracking by the steering box. I'd just look for a junkyard wonderbar, and if you can't find it, then get the TDS one.
Old Nov 3, 2008 | 02:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: wonderbars
Mine cracked anyways. With the braces and wonderbar. Go figure.
Old Nov 3, 2008 | 04:29 PM
Car: 1987 IROC-Z
Transmission: TH350
Re: wonderbars
Originally Posted by TheScaryOne
I couldn't get a wrench in the recessed holes on the lower part without pulling the wonderbar.
The wonderbar does block the lower fan mounting bolts. I know because I was just under my car last night.
Old Nov 3, 2008 | 04:32 PM
Stephen's Avatar
Car: 87 GTA
Re: wonderbars
I musta done something "wrong" then. I pulled my fans a few months ago, without touching the wonderbar.
Old Nov 3, 2008 | 04:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: wonderbars
My Global West Wonderbar interferes with the lower attaching points on my thirdgen dual fans.
JamesC
Old Nov 3, 2008 | 06:58 PM
Axle/Gears: 3.27 BW
Re: wonderbars
Well, it seems that it's a Bird/Camaro difference. The Camaro guys say it interferes, the bird guys have no problems. Interesting.
Old Nov 5, 2008 | 03:35 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
Re: wonderbars
what about spohn? they have an adjustable one. check it out
Old Nov 19, 2008 | 11:24 AM
cabmustang's Avatar
Re: wonderbars
Well I ended up getting the UMI wonderbar, and I was just wondering if I have to raise the front of the car to get it in or if I just have to unbolt the sway bar.
Old Nov 19, 2008 | 11:38 AM
JamesC's Avatar
Re: wonderbars
I'm unsure of how you can swap the bar in without raising the car a bit. IIRC, you can mount the bar by simply unbolting the sway bar.
JamesC
Old Nov 19, 2008 | 03:34 PM
cabmustang's Avatar
Re: wonderbars
So you're saying I can just unnbolt the sway bar bushings and leave the end links connected and just swap in the bar?
Old Nov 19, 2008 | 04:03 PM
JamesC's Avatar
Re: wonderbars
Yes.
JamesC
Old Nov 19, 2008 | 06:13 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
Re: wonderbars
Do the dual fans make a big difference in cooling. My GTA seems to get very hot in the summer.
Old Nov 19, 2008 | 06:19 PM
Stephen's Avatar
Car: 87 GTA
Re: wonderbars
Why are you asking a cooling question, in a wonderbar thread? This forum doesn't have anything to do with cooling systems.
But.....Your GTA should have dual fans stock. If it doesn't, someone took them off or the car isn't really a GTA.
I suggest reposting in the correct forum.....Not a cooling problem, in the Suspension forum
Old Nov 19, 2008 | 08:18 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Re: wonderbars
Sorry. I didn't know my car had dual fans on it. My bad. I was also interested in the Wonderbar for my car as well. Sorry.
Old Nov 19, 2008 | 09:01 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: wonderbars
have the TDS wonderbar on my 87 formula 350 and i just took my dual fans off about 2 weeks ago. had no problem and left the wonderbar on there.
dual fans help with cooling but u need to have the cooler fan switches... sold by jet and hypertech. i also wired both fans together and run them off the hypertech 177on 166off fan switch. it never gets hotter than 180 at 100degree temps in traffic during the summer.
Old Nov 19, 2008 | 09:22 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Re: wonderbars
Interesting. There is still allot of things I don't know about my TA. I haven't had it that long and is stored for the winter right now here in Iowa. Thanks for the help.
Old Nov 27, 2008 | 06:36 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: wonderbars
for the guys having issues, you can cut the bottom have of the recess of the fan mounting surface off.
without a full circle there blocking the wrench, you can use a 13mm rathet wrench and go to town on them once you open up the bottom.
i got frustrated the 1st time i couldnt get my fans off and came up with a plan.
Old Nov 28, 2008 | 11:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: wonderbars
have the TDS wonderbar on my 87 formula 350 and i just took my dual fans off about 2 weeks ago. had no problem and left the wonderbar on there...
That's because the TDS version of a wonderbar doesn't interfere with the lower fan mount on dual fan equipped cars. The reason why is very simple. The cross bar on mine is mounted closer to the sway bar, in other words, further back from the lower dual fan mount bracket. All other versions use a design that welds the bar to the end of their mounting brackets which puts that bar far closer to the lower dual fan mount bracket. The difference is in the design.
Lon Salgren
Old Nov 29, 2008 | 08:23 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: wonderbars
Lon Salgren
100% correct!
the bar diameterhurts as well. my spohn is larger than a TDS version.
not that one works better than the other. both are great pieces.
Old Dec 3, 2008 | 10:51 PM
JERRYWHO's Avatar
Re: wonderbars
And a cnc press brake, mill, lathe, plasma cutter, tube bender and TIG welder.
You end up with this, a wonder bar that bolts to your strut tower brace.
Jerry
Old Dec 3, 2008 | 11:22 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Re: wonderbars
damn thats a trick set up man..are you running this in your maro?
Old Dec 4, 2008 | 08:10 PM
JERRYWHO's Avatar
Re: wonderbars
Got it back from powder coat yesterday and installing it tonight on my 90 Camaro.
Jerry
Old Dec 4, 2008 | 09:01 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: wonderbars
Wow.... my head hurts from that thing... I can't figure it out lol.
I need mounting pictures lolz.
Old Dec 4, 2008 | 09:24 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Re: wonderbars
Jerry
Lets see some installed pictures when you get it in!
Old Dec 4, 2008 | 11:05 PM
Stephen's Avatar
Car: 87 GTA
Re: wonderbars
Please elaborate how that mounts. Some of it is obvious, but some....
Old Dec 4, 2008 | 11:27 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: wonderbars
HOLLY OVERKILL BATMAN, looks sexy though. How heavy?
Old Dec 5, 2008 | 01:11 AM
Car: 87 TA clone
Re: wonderbars
wowwww... lol alil overboard huh lol. looks cool tho, not sure all thats needed but id do it anyway. wats the weight and tubing size? and def gets sum pics up of it installed
im gona be making a 1.5"x.095" DOM mild steel strut tower brace for my 87 formula350 but im making it to fit my HSR which is taller than the TPI... i wanna see how much clearance u got wit yours even if its on a TPI.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
