Car won't go when wheels are cut sharp
I have a 90 RS. When I turn the wheels sharp either direction, the car tries to stop. When I try to turn around anywhere, the car struggles to go unless I turn the wheel in the other direction than I am going. What could this be?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Car won't go when wheels are cut sharp
have you done any brake upgrades? I though i read somewhere that the 1le upgrade, or the ls1 when done a certain way, the caliper hits the steering stop on the a-arm, thus applying the brake on that side?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
This kind of happens to me, but only when my feet are off both pedals and i'm just rolling. It's because the wheels are pointed slightly different directions at full lock and are therefore trying to roll along two different axes and well we all know what happens when that happens.
Car: 85 camaro z28
Transmission: auto to manaul
i have the same probelm. when u turn the wheel all the way to the L or R, the tire jumps up and down and alot virbration right. im think ball joint or control arm bushing. ill figure my problem out in the morrning
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I've never had a problem like this. You might want to check the steering components and have the front end alligned.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mine does that but nothing is stock.
Tubular k-member and a-arms means I don't have steering stops and can easily turn more than a stock steering system can do. Running 27.5" tall front tires and no steering stops means the tires actually hit the inner fenders when turning really sharp.
My center link is flipped over so I could drop the engine lower. I have no idea if this affects the Ackerman angles. http://en.wikipedia.org/wiki/Ackerma...ering_geometry
Lastly, I have very big slicks and a spool which makes turning difficult.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
kah992
Aug 19, 2015 02:55 PM
db057
Aug 11, 2015 10:11 PM
