Lowering/bigger rim size
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
im driving a 1990 camaro rs....i like how it sits for the most part....it has 15s on it i would like to put 16s or 17s on it and lower it a TAD any suggestions on the suspension to go with to keep it riding smooth? and will the rims fit if i lower it
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Lowering/bigger rim size
They'll fit if you lower it. You won't really loose much ride quality if you change wheels, but if you want a smoother ride, good shocks are what you want.
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
ight thank you so you think the 17s would look better then the 15s in your opinion...and wouldnt happen to know a place that has the z28 chrome rims do ya?
Car: 1991 RS Camaro
Yea, I like the look of 17s more than 15s. But tires are more expensive. And if you get 17x9s, you'll probably need wheels spacers.
Which Z28 rims are you talking about? There are alot of different ones.
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
i think im gonna go with 16s i love these rims http://www.wheelhq.com/16inch-chrome...ro-wheels.html i just dont wanna spend $1000 on just rims....
Car: 1991 RS Camaro
They do look nice. I don't know if I'd want to spend that much either. Look around some more. Might be able to find a better deal. Those are more commonly reffered to as IROCs, not Z28s.
Car: 1988 Convertible Iroc Camaro
If you didn't already get your tire and rims , here's a setup my husband just put on my 88iroc . 18x8 chrome irocs and tires for 1300.00 mount balanced and shipped to my door the next day ! Car was lowered using 1" lowering springs from Summit and cut 3/4 coil off front and 1 1/2 rear CAR LOOKS AWESOME. If your intersted in how it looks I'll send pics.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
if youre set on 16" iroc's just pick up a used set for cheap, polish them up and you'l spend less then 1,000. but if your gonna update rim's might as well go 17's and up, make it worth while but iroc's truly belong on irocs though imo
Linson
Sep 21, 2015 01:08 PM
