9 bolt help...
Old Dec 2, 2008 | 01:50 PM
choekstra17's Avatar
Car: 1992 camaro convertible
Engine: 355ci carbed
Transmission: t5 5 speed
Axle/Gears: 10 bolt 4:10 gears
9 bolt help...
Ok, I bought a 9 bolt rear end with 2:73/2:77 gears (obviously a 2 series carrier. I took it apart, bought a 3 series carrier (made sure it was the 3 series carrier) then bought a set of US gear/Strange 3:70 ring and pinion set with master install kit. I brought it to a shop to install them gears and axle bearings etc. When the mechanic got around to the ring and pinion end of it he has had problems gettimg the pinion gear in. Needless to say the rearend has been in the shop for 2 years and i am pissed!!!! He, for some reason, can't get the crush sleeve to crush even with up to 375 ft/bls of torque and wants to give up and charge me to get it back. I don't believe i should pay for an unfinished job but thats besides the point. My question is, is there any one who has done one of these and maybe give me some insight on what he might be encountering on why he is having trouble doing this. He even bought a new set of gears and rtied them and had the same problem. I now got over $700 into this rearend in parts and dont want to thow it away. PLEASE HELP!!
Old Dec 2, 2008 | 01:57 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt help...
What do you mean he cant get it on? Can he get it on but not fitting into the rear?
Old Dec 2, 2008 | 02:19 PM
Re: 9 bolt help...
he put the new shims and pressed on the new bearing, then slid on the crush sleeve ans put the pinion shaft through the pumkin, put the yolk over the shft from the outside of the pumkin. put the washer and nut on and tried to tight the nut down and crush the crush sleeve to the right depth but it wont crush.
Old Dec 2, 2008 | 09:54 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 9 bolt help...
That's a question for big gear head. He's around here somewhere...
Old Dec 3, 2008 | 10:48 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: 9 bolt help...
There are two different large pinion bearings for them, he must have the wrong one installed.
I had the same problem and that was the cure.
Old Dec 3, 2008 | 11:28 AM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: 9 bolt help...
Dyno Don is correct
Old Dec 3, 2008 | 11:52 AM
Re: 9 bolt help...
hey that sounds like it could be it. thanks for the help. Do you know where i can buy just the pinion bearing from.
Old Dec 3, 2008 | 12:23 PM
RedLava's Avatar
Car: 86 z28
Re: 9 bolt help...
http://ratech.stores.yahoo.net/79bogmax.html
Old Dec 3, 2008 | 12:40 PM
Re: 9 bolt help...
Wow thanks for all your help. I should have came on here 2 years ago. Thats how long the shop has had my rear end.
Old Dec 3, 2008 | 01:13 PM
Shagwell's Avatar
Car: projects.......
Re: 9 bolt help...
glad those guys had an answer for you - just for reference, this would have "fit" better in the drivetrain board than suspension
2 years? seriously? wow.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Zane Story
Oct 8, 2015 12:40 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
