15X10 5" BS
Old Dec 4, 2008 | 10:36 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
15X10 5" BS
Would the wheels stick out too far on a Iroc? I like these wheels from centerline and actually 2 others from the same line. But the deepest they BS them is 5".
What do you guys think?
Old Dec 5, 2008 | 04:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 15X10 5" BS
it will stick out almost an inch, thats just the rim, then the tire will add more. Sorry, but unless you narrow the axle they wont work.
Old Dec 5, 2008 | 06:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 15X10 5" BS
Common backspacing for a 15x10 is 5.5". A 5" backspace will push them put 1/2" more.
Depends on what tires you want to put on them.
Old Dec 6, 2008 | 11:59 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 15X10 5" BS
Better to get 6" BS because then you can get spacers as needed, while you can't un-space a 5" BS.
Old Dec 6, 2008 | 12:26 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Re: 15X10 5" BS
I'm planning on running MT 275/60 drag radials. The 5" bs is the most they offer. Other options are same wheel in a 8" with 4.5 bs and 255/60 drag radial. I'd rather have the 10 though unless everything sticks out too far.
Old Dec 6, 2008 | 05:07 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 15X10 5" BS
There's no good reason you can't put the 275 on the 8. A non-GM magazine did a test a while ago, with 275/60 BFG drag radials on 8" wheels versus 275/50s on factory 7s. They noted that they were getting the entire tread on the pavement with the 8s.
C409
Dec 17, 2016 09:35 PM
Dialed_In
Aug 20, 2015 01:45 PM
supermaxxbasher
May 19, 2005 12:34 AM
89formula#1
Aug 25, 2003 05:57 AM
ryn28
May 27, 2002 11:09 AM
