will 15x10s fit ??
Old Aug 23, 2003 | 10:34 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
will 15x10s fit ??
Hey guys my freind bought a set of Weld Draglites for his drag car but isn't using them. Hes got 15x3.5 in the front with new tires on them and 15x10's in the back with no tires and he said he woudl sell me all 4 rims with the front tires for 400bucks. now the back rims have never been mounted on a car and the front ones were on his bird for like 3 weeks so basically there brand new. Well my question is, would a 15x10 inch weld draglite fit on the back of my car with no modding? Also what woudl be the smallest tire i could put on it and not have it be to small? a 255?? thanks guys. Oh yea does anyone have pics of a bird with the ultralites on there car?? thanks
Old Aug 24, 2003 | 12:34 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
What backspacing are the rims? I have 15x8 with 5.5" (stock) backspacing. With 28x10.50 slicks I had to beat in the wheel wells but NOT because of the width of the tire but because of their height. If I ran 26" or 27" x 10.5" tires I'd have no clearance problems whatsoever. As long as you have anywhere from 4" to 5.5" backspacing and run the smallest tire (like you said) you'll be fine...
Old Aug 24, 2003 | 02:48 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
A friend of mine has 15x10's on his 3rd gen. Not sure of the back spacing but he has 295/50R15 BFG Radial TA's on them and they dont rub. But he also has adjustable rear shocks so that might make the diference, and they do stick out of the side of the car abit. Looks sweet though.
Old Aug 24, 2003 | 03:10 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
smallest tires width wise i would put on a 10 inch wide rim is a 275.. 255's will fit but they wear wrong and look silly.. just make sure the backspacing is correct for your car or your gonna be replacing wheel bearings quite a bit.. slight modifications to the wheel wells are probably gonna be nessicary.. nothin too much just some massaging with a bfh and it would probably help to roll the lip of the wheel well a little
Old Aug 24, 2003 | 05:47 PM
Car: 89 Formula
Engine: Carbed 5.7
Ok now would a 265/50/15 be fine on the 15x10 inch rim? I work at pepboys and I can get the GLS tires for around 55 bucks a peice in that size. Also My freind said they are 4.5 inch back spacing. Is this bad?? is it gonna look goofy?? And one more thing, How is it driving aroudn with skinnies on a car? IS it really reallu unsafe? thanks
Old Aug 24, 2003 | 10:56 PM
Car: 89 Formula
Engine: Carbed 5.7
Alright well he isn't sure if he wunts to sell them anymore so wuts a diff rim that would look cool on our cars?? formula so no ground effects. Oh and i came up with a new saying for our cars, "When you drive an F-body, You don't get to F-anybody" lol
Old Aug 25, 2003 | 05:55 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I'm running 15x10 w/ 5.5 back spacing. Tires I would run a minimum of 275's in a radial or 10.5 in slicks, I'm running 27x11.5 Hoosiers right now and have TONS of clearance, no beating anywhere.
Old Aug 25, 2003 | 05:57 AM
IHI's Avatar
IHI
This is a from behind veiw to give you an idea how they look with the fender lip. This pic was taken with my old 26x9.5 slicks so they look like low rider tires all stretched out, but the new ones fit/look better.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
