"Wheelrite" measurement tool
Old Dec 13, 2008 | 02:48 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
Anybody ever use one of these? I am thinking about purchasing one. Any opinions?
Old Dec 13, 2008 | 02:52 PM
Twin_Turbo's Avatar
Re: "Wheelrite" measurement tool
It's an overpriced plastic POS. It IS handy but way too expensive for what it is, basically plastic and a piece of coat hanger wire.
Old Dec 13, 2008 | 03:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
won't tell you if a tire would hit anything. just ask what size rim and backspacing you want or do a search.
Old Dec 13, 2008 | 03:48 PM
Twin_Turbo's Avatar
It will tell you if a tire hits. The thing mimics a rim and the coat hanger wire can be bent to represent a tire
Old Dec 13, 2008 | 04:44 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
or you just use a straight edge and measuring tape.....
Old Dec 13, 2008 | 05:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
exactly. Its quite easy, and cheap/free if you already have a tape measure or 2 yard sticks
Old Dec 13, 2008 | 09:39 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Maybe easy for you, but I have a hell of a time trying to hold all of that together and measure for clearance at the same time.
The thing that concerns me about the "Wheelrite" is that the actual tire simulation doesn't seem like it would be very accurate. I mean when they give a section width, where is that measured? Is it at the widest part of the sidewall? How could you bend a piece of wire in the shape of the outline of the tire and have the correct section width and tread width if you don't know where the section width is measured? Did that make any sense?
Maybe I'll just make my own jig. Maybe I will call Percy's and get their take on the deal.
Old Dec 14, 2008 | 12:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you need to hold a straight edge on the rotor/drum face, and measure back with a tape measure. Not rocket science. It will give you a good idea of what kind of clearance you have in the wheel well and you can figure out a tire/rim combo from that.
The tool you are showing will allow you to figure of the height of the tire, but i dont think it will work well with a large tire with a lot for sidewall and bulge, like a slick or drag radial on a 15" rim, its more for low profile tires or larger rims where there is not a lot of bulge.
Old Dec 16, 2008 | 08:29 AM
BMR Sales's Avatar
Former Sponsor
Yeah when Percys first had the wheel rite at PRI (some years ago) it was a billet aluminum piece. I looked at it and decided when they came out with it I was going to buy one. Well after I saw it in a magaazine I orderd one cause it was only $60. But it is a flimsy piece of plastic not worth the $60 I spent on it.
Best thing I hve found for measuring wheels is have a spare wheel you know all the dimensions for. Use it for mock up then either do the math on paper or find an online wheel offset calculator and punch in the dimensions of the wheel you have. Then play with the width/offset of new wheels and the calculator will tell you how much the inner and outer lips move, transfer that to the mock up wheel and see if anything hits.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
AUZ28
Oct 3, 2015 06:28 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
