Ride height measurement
Old Dec 23, 2008 | 08:41 AM
mark87Z28's Avatar
Where is this measurement taken? From the rocker extensions to the ground?
Old Dec 29, 2008 | 08:53 PM
1988-305-tbi's Avatar
Re: Ride height measurement
measure from the ground to the fender lip, should be around 26"-27"
Old Dec 29, 2008 | 09:17 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Front or rear fender?
Old Dec 30, 2008 | 12:59 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
there are no "rear" fenders they are quarters panels
Old Dec 30, 2008 | 09:53 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
LOL ya i know they're called quarter panels, just wanted to make sure what he was saying, in the manual they say something like 51 inches, but thats from the roof I THINK.
Old Dec 30, 2008 | 05:52 PM
FueledSoul's Avatar
There are many ways to measure ride height. there is no one standards to measuring height in less there are rules set on height in witch case a standard would be formed and messering points would be addressed and used constantly. messering from the ground to roof is very inaccurate and would only sever a general estimation on hight. a good rule of thumb for the street is you'll want to use 4 or more points to a vehicle to be the most accurate as possible. So if you planed on changing a vehicles ride hight get a base setting first using your points you picked so when you do change it you can go back to those points and see the changes made
Old Jan 1, 2009 | 06:40 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Inconsistancies in build makes exact measurements hard to get at any point. I think the most consistant/ correct is from the bump stop mount to bumpstop contact point. But, the one I've seen the most is the lower lip of the fender well (either front fender or rear quater panel).
Old Jan 1, 2009 | 07:00 PM
Stephen's Avatar
Car: 87 GTA
My 87 GTA, stock height & stock tires.....26" front,27" rear
Old Jan 1, 2009 | 07:29 PM
FueledSoul's Avatar
I really like using the fender and quarter lips to the center of the wheel hubs. i find this is the most accurate way of measuring you have very few variables. Think about this from a logic standpoint your taking the tires, rims and air pressure out of the equation
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
skinny z
Oct 5, 2015 06:23 PM
AUZ28
Oct 3, 2015 06:28 PM
Vincent135
Sep 28, 2015 10:50 PM
