Rear end movement
Old Jan 6, 2009 | 09:15 AM
mark87Z28's Avatar
Rear end movement
When accelerating through a left turn the rear end will swing out while the rear tires are planted. Sometimes when accelerating in a straight it seems as if the axle is jerking like the rear trailing arms may have some bushing issues. Am I on the right track?
Old Jan 6, 2009 | 09:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear end movement
Check the panhard and panhard brace as well as the LCA's.
JamesC
Old Jan 12, 2009 | 11:05 AM
mark87Z28's Avatar
We pulled one of the rear trailing arms. The bolts were corroded, the rubber bushings were in decent condition, but there was a lot of slop in the metal inserts where the bolts slide through. We do not have a point of reference to determine how much play is too much play. Should there ne any play in the arms when they are tightened?
Old Jan 12, 2009 | 11:57 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The trailing arms will have some side to side play. They act as two force members, resisting only tension and compression. The pan hard bar and its associated brace provides the side to side control of the rear end.
If you add up the cost of replacement bushings for the rear control arms along with the effort to install them, a set of lakewood control arms from Summit, etc. for around $100 is a good buy.
Old Jan 15, 2009 | 08:54 AM
mark87Z28's Avatar
I went to NAPA to look at their replacement bushings and the metal inserts were much tighter than what is on the car now. The machinist quoted me $20.00 to press each bushing. They can forget that.
Old Jan 15, 2009 | 10:05 AM
naf's Avatar
naf
You'll be happy with the lakewood LCA's. I love mine.
Old Jan 16, 2009 | 12:16 AM
406z's Avatar
Car: 1984 Z28
Engine: 406
Transmission: 350th
Axle/Gears: 373:1
Side to side movement has more to do with the panhard bar. The lakewood lca's are a good buy. You can also check out ebay for some killer deals on them. I got a pair of sphon adjustables for 120. I would atleast replace the bushings on the panhard bar since you're already down there.
Old Jan 16, 2009 | 02:18 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
20 a bushing !? wow just use 2 pieces of metal, a bearing race and a big c clamp lol
Old Jan 16, 2009 | 05:43 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I bought the stock bushings, but pushed through 1/2" 13 Grade 8 bolts.. Makes you feel a bit safer than the 3/8 ones that were in there..
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
