k member welding?? advice...
Old Feb 1, 2009 | 03:17 PM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
i have a 1989 iroc 5.7
i recently bought the car and i just had the stering gearbox replaced (i could barely drive the car, the steering had a ton of play before it would turn). so i got the play taken care of but they noticed my frame cracked where the gerabox bottom bolt mounts, there is actually a hole in the frame. so when you turn the steering gear moves side to side about 3/4" so the car is all over the road.
i am tight on cash with this economy crap so i am wondering if this can be welded or if not, does anyone know how labor intensive it is to replace or how much i might get charged for labor if i have it replaced?
thanks
Old Feb 1, 2009 | 03:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: k member welding?? advice...
so the frame cracked? common problem. It can be welded up, its just sheet metal. Have a welder fix the problem, then get a wonderbar to reinforce the front frame.
http://www.umiperformance.com/produc...ategory_id=112
i dont know where the hole is, but if its just a crack, it can be filled with weld, if its a hole, a plate needs to be welded over it.
Old Feb 1, 2009 | 09:25 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Yes it can be fixed but it would be a good idea to have a frame shop to it so that they can insure that the frame holds to factory spec.
Old Feb 1, 2009 | 10:40 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
dont IROC's have a wonderbar stock?
Old Feb 15, 2009 | 12:25 AM
jjskibbs's Avatar
Car: '89 IROC
well, the hole is right where the bottom bolt of the steering gear is supposed to go. we tried welding the cracks but the the fram is just breaking away, i think i need to replace it. prolly get one of the spohn tubular ones. anyone kow what i can expect for labor time/cost to replace the k-member?
Old Feb 15, 2009 | 12:48 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Getting a new tubular k-members not going to fix your frame issue - i read that right? you should post some pics of the damage its a lot easy for us to give you ideas or advice rather then trying to read it, seeing it first hands key. fix the frame first, get a wounder bar (put it on the rack and get an aliment) checking the frame is around $50 its when they have to pull thats where it cost money. if you have basic skills and tools replacing the k-member by your self is easy
Old Feb 15, 2009 | 12:52 AM
jjskibbs's Avatar
Car: '89 IROC
thanks. i think i had my info wrong... my k-member is fine, it's the part where the geerbox mounts that is damaged. i believe that is called the front subframe, correct? so yeas that part needs to be fixed or replaced... can that be repalced reasonably?
i will try and get some pics up...
car already has a wonder bar by the way
Old Feb 15, 2009 | 09:44 AM
WIll36's Avatar
Engine: 355, 408
Fueled soul is correct the steering box mounts to the front subframe. The best thing to do is for you to post some pictures. Unless it is completely gone a good frame shop can fix it. What it will cost is going to be totally dependant on the shop. After it's fixed definetly get yourself a wonder bar and I would also try and track down a pair of factory K-member braces.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
meeklay812
Oct 1, 2015 03:46 PM
