BMR Pre-Spring Lowering Spring Sale!!!!
BMR Lowering Springs - On Sale Now!!!
38% Off Rear Springs
$79.95 per pair
Tech Specs: Rear Lowering Spring (SP003)
Please Hurry - Spring supply is limited and the sale will end when we run out of springs from this batch!!
Order by clicking here or by calling BMR at (813) 986 9302:
http://www.gnetworks.com/v4/go.gnf?s...ult&d=products
Springs can also be ordered through an authorized BMR Distributor: http://www.bmrfabrication.com/distributors.htm
$79.95 per pair
- 1" drop
- Working linear rate of 170 pounds per inch
- The BMR spring is very streetable, but slightly aggressive.
- The BMR spring has an i.d. of 2-9/16" on the bottom so it will fit properly on the rear axle spring perch (o.d. of 2.5").
- Weight - 7.4 pounds per spring
- Powdercoated red
- Made from high-tensile silicon chrome steel (same material used by most NASCAR teams)
- BMR springs are Proudly Made In America
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: BMR Pre-Spring Lowering Spring Sale!!!!
That's not a bad spring for handling purposes. If I had anything but dust in my wallet, I'd grab a set to replace my rear Eibachs since they're linear.... they are true linear springs, aren't they?
We offer the coilover conversion for the front but not the springs by themselves.
Yes ours are.
That is a pic of the coilover conversion with the A arms. You can get the coilover conversion by itself if you would like.
Car: 1991 Trans Am
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
those springs look progressive and are. tightly wound at the bottom and less at the top. just like the sportlines/prokit. they do look beefer than the sportlines.
this is my thread where i sold my sportlines, pics of the new linear moog5665s(black) right next to the progressive sportlines(red)
these are linear. even spaced from top to bottom.
http://www.ma70.com/bishop/pics/tokicosprings.jpg
these are progressive... and they are BMR springs
http://www.vincihiperformance.com/vi...BODYSPRING.jpg
this is the main page for the link above
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
ambainb
Apr 25, 2016 09:21 PM
sailtexas186548
Aug 26, 2015 03:32 PM
