My TA's Stace, problems???
Old Mar 7, 2009 | 12:42 PM
miamivice's Avatar
Car: 88 GTA
Hi Guys:
I need advice/expertice on this. We installed brand new eibach pro-kit springs, kyb shocks, and brand new tires on the car. I thought it would drop the car, but didn't really do much. I know that the original springs may have been sagging...so I guess I can understand. However, the front end is sticking way up vs. back.
One of the guys at the shop says "it will settle." But really...that much?
The car has a 350 in it. I did remove the AC (and put an AC delete box in its place), and removed a few other things out of the engine bay like cruise control, etc. But I can't imagine that would take so much weight off the front end to cause the front sitting that much higher.
I am at a loss here. What do you guys think?
Old Mar 7, 2009 | 01:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: My TA's Stace, problems???
Thats deff. a big gap from the wheel to the fender lips. DId you index the springs in the pocket right? They will settle some when you start to drive the car.
another thing is the profile on those tires. They look like something you would put on a s10 or someting.
Old Mar 7, 2009 | 09:33 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I have the same setup as you. I have Eibach Pro Kit and KYBs and they are great. I have stock tires and the stance is lower by an inch. I find it very good. I dont know what your problem is unless the springs are not in place properly.
Old Mar 8, 2009 | 07:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unsure that I buy the whole "settling" business. I replaced both fronts and rear springs over a year ago. No measured settling whatsoever. TPI and yankee are correct. If the front springs aren't indexed properly the car will ride like a 4x4.
JamesC
Old Mar 8, 2009 | 12:51 PM
miamivice's Avatar
Car: 88 GTA
Thanks for your responses. I will have to check the seating on the front springs. Is there anything I should check on the backs? Anything else in general to note?
The tires on the car are the factory size for 1982 --- 215/65/15.
Old Mar 8, 2009 | 01:21 PM
JamesC's Avatar
No indexing on the rears; however, you might check to see if the springs are properly seated in the pockets.
JamesC
Old Mar 8, 2009 | 01:44 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
The rear I always remove the isolator from the top and slide a piece of hose over the 1st coil just so its not metal on metal.. This give you a little more of a drop also.
Old Mar 8, 2009 | 01:48 PM
JamesC's Avatar
On my car that was good for 1/2".
JamesC
Old Mar 8, 2009 | 04:07 PM
Dr G's Avatar
JamesC is entirely right about the spring indexing. Mine was wrong and it made the car much higher, like yours. Search for the threads by EdMiller and others about how to do it and give it a try.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
