Front Suspension
Old Mar 12, 2009 | 05:05 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Front Suspension
I wanna do a little bit of work on my stock front suspension. What would you guys recommend?
I'm not trying to go crazy, just a couple small things for a smoother ride.
Old Mar 12, 2009 | 05:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Front Suspension
Is there a problem now? ie. anything broken or misadjusted?
Check and see if your shocks are worn out, replacing them can make a world of difference.
Poly sway bar bushings are a great cheap upgrade.
Old Mar 12, 2009 | 05:44 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Nah it just rides rough, and it gets shaky when I get up to speed. I wanted to do sway bar bushings, shocks, and ball joints.
Will that be good?
Sonix's Avatar
Car: 1982 Trans-Am
Yea, check tie rods while you're there.
Replace the wheel bearings too.
That should do the trick. Get it aligned after you're done and see if it's better.
Old Mar 12, 2009 | 06:03 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Alright I'm going to do that today. It's gonna make a difference regardless right?
Old Mar 12, 2009 | 06:11 PM
FireTurdWS626's Avatar
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
My car handled rough and shakey, so what i did is I got a steering rebuild kit from Hawksthirdgenparts.com, Bilstein struts and shocks, my lower controls arsm were bent so i got tubular ones from BMR (available through hawksthirdgen) and I got Poly urethane sway bar bushings and sway bar endlinks, and may i add my car was already equiped with the biggest swaybar available which is 36mm from factory. Note*** swaybar bushings for a 36mm are not available through autozone, kragen, oriley, csk, or the dealership because its discontinued. I got mine from Hawksthirdgen but I found out that you can get them from Napa Auto Parts. Its still a rough ride but only on rough streets, the car handles like a rollercoaster now its an amazing differance, and it got even better once I changed my tires to BFgoodrich g-Force(s).
some other things you can do to inprove is get a tubular panhard bar, rear tubular or boxed controls arms, lowering springs, and Sub-Frame connecting rods.
Note** tubular lower front control arms come with poly urethane bushings and heavy duty ball joints
hope this helpped you.
peace out and good luck.
-Rob aka fireturd
Old Mar 12, 2009 | 06:37 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Spohn does it again and for only $300
http://www.spohn.net/shop/1982-1992-...GM-F-Body.html
Old Mar 12, 2009 | 06:50 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Alright thanks for the advice, I'm heading to Napa right now to get some goodies.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
