wheel hop??
Old Mar 12, 2009 | 10:44 PM
89stangkiller's Avatar
Car: 89 IROC-Z Camaro
Engine: 5.7 TPI
Transmission: AUTO
Axle/Gears: posi 3.08
wheel hop??
how would i prevent wheel hop...some ppl say its the shocks or tire pressure..???
Old Mar 13, 2009 | 08:03 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: wheel hop??
My opinion is the weak "U" channel rear LCA may be the cause of the wheel hop. Since I replaced mine with the Spohn tube type, I no longer have that problem. Again it just might be me.
Old Mar 13, 2009 | 09:11 AM
Shagwell's Avatar
Car: projects.......
Re: wheel hop??
Wheel hop in simple form is the shocks' in-ability to control the motion of the rear end/suspension. That said, tire compound/pressure, suspension geometry, spring rate, power level and gearing all effect the shocks' leverage to do their job.
To remedy the problem, always start with the simple stuff; these cars are old. New shocks and new bushings go a long way, if you intend to "hot rod" it much then you would be money ahead to look into some aftermarket lower control arms.
Old Mar 13, 2009 | 09:17 AM
BMR Sales's Avatar
Former Sponsor
Re: wheel hop??
Another inexpensive mod to help is relocation brackets, if the car is more or less a drag car. You might not want to use them on a road race vehicle.
Old Mar 13, 2009 | 12:57 PM
UMI Sales's Avatar
Re: wheel hop??
Hello
Lower Control Arm Relocation Brackets are designed to eliminate wheel hop and give you the adjustments that you need to keep the power to the ground! I just wanted to through that out there. And below is a link to show you what we have to offer. If you have any other questions feel free to ask and I will be glad to help!
http://umiperformance.com/products.php?category_id=108
Thanks for your time!
Brad
Old Mar 13, 2009 | 01:02 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: wheel hop??
those are the ones i used solved my wheel hop and i still have the factory control arms.
Old Mar 13, 2009 | 04:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: wheel hop??
If your car sitting on level ground has the LCA's going UP in the back (angled upwards), then you have improper LCA angle, and you need LCA relocation brackets. No amount of other work will solve that, because you're power will force the axle up, and it will hop. You can try to work around it with spring and shocks, but you're fighting a losing battle.
If your LCA's are going DOWN in the back (lower at the back then the front of the LCA), then your angle is correct, and shocks and bushings should be looked at.
Old Mar 13, 2009 | 06:34 PM
Engine: 5.7 TPI
Transmission: AUTO
Re: wheel hop??
you replaced your shocks?
Old Mar 13, 2009 | 06:35 PM
Engine: 5.7 TPI
Transmission: AUTO
Re: wheel hop??
well i said my shocks because their bad and im going to replace them asap so i was sayin would that help a lil bit?
Old Apr 11, 2009 | 03:55 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
Re: wheel hop??
i
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
