Tire Recommendation Wanted
Old Mar 16, 2009 | 09:17 PM
Flynt's Avatar
Car: 1988 Camaro IROC
Transmission: Auto overdrive
Axle/Gears: 3:23
What brand tire would you recommend for a 1988 IROC? I am using the stock 16 inch wheels and want the new tires to be the original size(245/50 by 16). The car will not be raced or driven in snow. The car will be driven to and from work on occasion so I want a good rain tire that has reasonable tread life. I do not want to spend more than $125-$130 per tire.
Any recommendations?
Old Mar 16, 2009 | 11:06 PM
rhit_rs's Avatar
Re: Tire Recommendation Wanted
Head to tirerack.com do some searching for tires in that size. I did a quick check and the Firestone Firehawk Wide Ovals seem to get good review. Also the Yokohama AVS ES 100 is a solid tire choice as well. If you want something stickier, you could go down to a 245/45/16 and run the Hankook RS-2 although it won't last nearly as long as the other two.
Discount tire direct is also a good place to check and read reviews.
Old Mar 17, 2009 | 12:56 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I've put about 2000 miles on a set of Nitto NT555s (255/285, 17"). They are great. I took them out in the rain and was still able to lay in to the brakes pretty hard at 45mph without losing it. Much better than my Kumho Ecsta ASTs, but those were really cheap.
Old Mar 17, 2009 | 01:15 AM
EvilCartman's Avatar
Car: '82 Z28
I'm running Sumitomo HTRZ tires and so far very happy with them. Drove in the rain they did surprisingly good, much better than my old tires. They're a soft tire though which is a drawback but their price is nice at 72 bucks each for a 245/50/16.
Old Mar 17, 2009 | 06:42 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you no doubt will get many opinions on tires . as a daily driver i have BFG G force sport tires on my car . i really like everything about them . cost is reasonable and made in AMERICA .
Old Mar 17, 2009 | 06:57 AM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
Yokohama is a great tire
Old Mar 17, 2009 | 11:40 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
After much digging and debating, I'm going with the Sumitomo HTR Z III. They don't have it in 245/50R16, but they do have the HTR Z, HRT+, and the HRT H4. LINK!
Old Mar 18, 2009 | 05:06 PM
Flynt's Avatar
Axle/Gears: 3:23
Thanks for the information.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
E Rod
Aug 28, 2015 05:17 AM
86camaroman201
Aug 19, 2015 04:52 PM
