2 stupid questions
Old Mar 17, 2009 | 09:07 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
2 stupid questions
first off, i have 2 rear sway bars currently, one from an 86 z28 and one from a 84 ta the ta one is quite a bit bigger but im pretty sure its hollow. which one is best? and im also looking for some bolt size as i hav had to cut almost all of the following during a rearend swap
lca bolts
panhard bar bolts
sway bar u bolts
any help is greatly appreciated
Old Mar 17, 2009 | 11:49 PM
1988-305-tbi's Avatar
Re: 2 stupid questions
if the sway bar is hollow it will weight less than the other smaller sway bar and it will have drain holes towards the endlinks..... i don't think any of the factory rear bars were hollow. may'be a aftermarket 22mm hollow or a hotchkis 1" hollow?????? . if your going to put a bigger sway bar on the rear you need one on the front the front as well
Old Mar 18, 2009 | 02:40 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
There weren't any hollow rear swaybars, stock, so the one of larger diameter will be stiffer.
The holes at the ends of the hollow front bars aren't drain holes, if the holes weren't there, there would be no way for water to get in to start with.
Apparently the holes were there to let the pressure out when the ends were welded up.
I'd just use the bigger rear swaybar. Bigger is better...
Old Mar 18, 2009 | 02:48 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Are they the same size measurement wise except for the tube size ? If its off a little bit, it will tear your end links up or cause unwanted tension/twist on the suspension.
Old Mar 18, 2009 | 03:48 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
His first post stated that they are both from third gens, so they should be 100% interchangeable, except for the bushings that mount it to the rear axle, and they shouldn't cause any wear or damage to his suspension.
Old Mar 18, 2009 | 08:14 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
remember the only stupid/dumb question is the one not asked . good luck .
Old Mar 18, 2009 | 08:59 AM
406z's Avatar
Car: 1984 Z28
Engine: 406
Transmission: 350th
Axle/Gears: 373:1
http://www.spohn.net/shop/1982-1992-...Hardware-Kits/
Ebay may have some sellers selling hardware as well. UMI, Spohn, and etc should all carry suspension hardware. The link above is to the Spohn site.
Old Mar 18, 2009 | 10:14 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Bigger isn't always better!
I had the 25.4mm Spohn rear bar on my car and even with the 36mm front bar, it caused throttle oversteer way too much. I switched to the 24mm GM bar and it's alot better now. Just remember, that if you go to the larger rear bar, you'll likely need a larger front to avoid oversteering. The suspension must be balanced.
Old Mar 18, 2009 | 12:06 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
^^^so putting in a 373 posi and a bigger rear sway bar at the same time isnt the best idea?
Old Mar 18, 2009 | 12:39 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
No its a good idea, just put the front sway bar on as well so everything is balanced!
I did not know that you could swap suspension parts from TA's to z28's :/
Old Mar 18, 2009 | 02:38 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
all i have is the rear sway bar, it came with the rearend
Old Mar 18, 2009 | 03:04 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
The sway bar is pretty easy to swap, just put it on, if your having problems, you know what it is
Old Mar 19, 2009 | 01:29 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
^^makes sense
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
