Front springs, need help asap.
Old Mar 24, 2009 | 08:35 PM
kevins_84_bird's Avatar
I have a 84 firebird with a v6 in it, the front springs are old, iv already bought front struts and rear shocks, i have came across a pair of front moog coil springs for $20, now the guy says there off a 3rd gen camaro. Doesnt say v8 or v6 or not, im wondering what the differance between the two are and if the 8 cyl springs will fit. Are there any downside to having 8cyl springs in a car with a v6.
Old Mar 24, 2009 | 08:51 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Front springs, need help asap.
Yes, the front end will sit high, unless they are lowering springs.
Old Mar 26, 2009 | 09:11 PM
Same with rear springs on a v6? If i where to install rear v8 springs on a v6 car would that jack up the back end a bit?
Old Mar 26, 2009 | 09:45 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Yes it would jack it up...it will also ride rougher. Ive seen ppl put v8 springs in the back to have that back raised look.
i would just buy a pro kit for your car. Ull be happy with the ride, stability, and stance.
Old Mar 26, 2009 | 11:40 PM
Where would I find a kit, do u have a link for this pro kit by any chance?
Old Mar 27, 2009 | 02:17 AM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
isnt the pro kit designed for 8 cyl cars?? i could see him gaining performance from the rear lowering but would the drop be the same on a 6 as in an 8 with the weight?
Old Mar 28, 2009 | 08:51 PM
Iv decided i'm going to use rear springs outta an old gm wagon, much stronger, and my *** end will sit higher.
Old Mar 30, 2009 | 12:57 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Try Canuck Motorsports for lowering springs- Third Gens look better with a balanced stance... if you want a jacked up rear, get a Second Gen and call Grumpy Jenkins or Wally Booth!!
Old Mar 30, 2009 | 05:15 PM
We all have our own opinion and thats yours, i need the rear jacked a bit so my rear tires dont rub the wheel wells. To be honest with you i would much rather a 2nd gen but no one will trade me
Old Mar 31, 2009 | 10:46 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Well, I like the lowered look myself but if you've got fat 60 series tires back there and not sitting up too high it'll look cool too. Later.
Old Apr 1, 2009 | 12:02 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Would a SC with an LG4 have the same rear springs as a SC with a V6?
Old Apr 1, 2009 | 12:47 AM
racerx520's Avatar
when i did my shocks and struts i bought a pair of front end springs from summit racing (i had already replaced the rears) and it said it was for my exact application, or i may have put down 5.7L cuz i plan on swapping the motor out when i can get the money...anywho, i couldnt even fit these springs in, i got the old ones out just fine, new ones...forget about it! we even went so far as to take two pieces of 1/2" metal, drill a hole in it, put a 1/2" bolt through it and tighten it down with an impact gun...did nothing, still wouldnt fit. i dont know why. i decided that if i had to compact the springs that far, then it would most likely just raise my front end up, so i stuck with the originals lol...i like the way it looks and IMO ithink theyre still working just fine lol...just figured that seeing as how iwas right there i'd try replacing them.
i returned them and got my100 bucks back lol
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
