list ride height with lowering kit
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I was wondering what the different results were with the different kits out there. I'll measure the other side to get an average tomorrow. I know this isn't the most accurate means of measuring it, but it should give people an idea of what they can expect from the different kits, cut Moogs, whatever.
My car (at the bottom of the fender lip) is ~25.5 front and 26.5 rear.
car has the mods in sig, fiber-glass hood, and about 40 lbs of stereo equiptment in the trunk.
Re: list ride height with lowering kit
Ground Control Weight Jacks, adjustable,
Front #1000 8" spring 26" front with plenty of room to go up or down at least 2 or more inches with a 26.4" tire. A 9" or 10" spring should work well with high spring rates the 8" is a bit shorter than necesary
Rear #200 9" spring 26 1/8" rear can go 1/2" lower or 2 1/2" higher with a 26.7" tire this is the shortest spring i could find and the adjusters are almost bottomed out, as low as i can go, with no spring isolaters
Car: 1991 RS Camaro
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
I have the Prokit w/ stock worn in isolators it only sits like not even .5" lower than stock, I'll measure later its on a jack right now.
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
28 in front 28.5 in back. everything is stock except OEM schocks and struts. id like to be around 25.5-26 in front and about 26-26.5 in back. so anybody tell me some decent priced lowering springs that may get me where i want? cheap springs, i cant spend a lot on this unfortunately. thinkin about cutting springs, but i like the idea of new springs in my car. suggestions?
actually i was just going to post the same thing, but can people give the dimension from the center of the wheel to the underside of the fender lip. this will take any variance out of the equation for wheel/tire combos, and allow us all to know how our cars will sit with our respective combos
Transmission: Pro-built 700R4
I have Jamex springs ft/bk. The rear isolators are from a '98 T/A. At the fender lip, the front measures 26" and the back 27".
25.7" front, 27.1" rear (16" 245/50 tyres)
Old WS6 suspension, probably sagged, possibly cut springs by a previous owner. Praise be to the lowered.
edit- actually, 91_5.7_tpi, what's your ride quality like? Mine's pretty bad, I had been wondering how much of a different new low springs/struts make as compared to old low spings/struts.
Thought I'd update this, changed from old WS6 springs to eibach pro-kit, is now 26.6" front, 28" rear. Wheels are still 16" 245/50.
The old WS6 springs didn't appear to have been cut, just sagged. I'm not particularly sold on the pro-kit... as one of my friends said "nice lift kit you've installed there".
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
wow, I'm at 26-3/8" up front with stock springs (can't accurately measure the rear since the gas tank is out and rear end was jacked up to get it out)...shows what 200k miles can do. I guess lowering springs will probably keep it about the same. Hopefully I can get a better ride quality with new springs and struts/shocks, though!
Car: 1991 RS Camaro
My car has the ProKit and I had to remove all the isolators on the car to get it close to where I wanted it to sit.
Mine's pretty rough on poor roads, but I love the feel of the car @ speed or on smooth roads. Probably attributed more to the KONIs.
Car: 87 GTA
Or do you think Chip Foose is a "hack"? We've all seen him cut springs on Overhaulin'.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm running Moog replacements. The front with 5662's sits at 26 5/8. The rear with 5665's is at 27 with 3/4 of a coil cut and the radiator hose mod.
JamesC
JamesC
That's probably it, I put new isolators in when putting the springs in. Ride quality is a tonne better than before, handling is shithouse.
Car: 92 rs & 89rs
Transmission: auto & t5
i have the dropzone springs. front is 25" rear is 26.5".got the springs off ebay for 80.00$ the only prob i dont like the rear springs. when i have someone in the rear and i hit a bump i bottom out.
Car: 1991 RS Camaro
Is shithouse good or bad? lol
Car: Iroc
Engine: 350 4-bolt
it kinda sounds bad? Dropzones are Ebay Name Brand. There more of a spring to add asthetics not as much performance. I almost bought them.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
It's retards that heat the springs that are Hacks. That totally destroys the rate of the spring.
ambainb
Apr 25, 2016 09:21 PM
Linson
Aug 21, 2015 02:12 PM
