Front Sway Bar
Old May 4, 2009 | 11:28 AM
RScamaropos's Avatar
Car: 1992 RS Camaro 25th Aniversary
Engine: 5.0 TBI V8
Transmission: 5 speed manual
Front Sway Bar
Hey guys
Im getting new bushings for my front stock sway bar, for a 92 camaro 305 (If that makes a difference). Does anyone know the diameter of the front sway bar so I can get the right fit? Thanks
-Darren
Old May 4, 2009 | 12:17 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Front Sway Bar
Look at your RPO code sheet. There are few options. FE1, FE2, FE3, F41... this will help you determine what diameter it is..
Old May 4, 2009 | 10:39 PM
Engine: 5.0 TBI V8
Re: Front Sway Bar
Well...seems I dont have the RPO code because i had to replace the center console arm rest and the original didnt have one anyway...Can i measure it?
Old May 5, 2009 | 07:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front Sway Bar
[QUOTE=RScamaropos;4146257Can i measure it?[/QUOTE]
Yes, use an adjustable wrench (monkey wrench). Measure in several places and then measure the distance between the jaws.
JamesC
Old May 5, 2009 | 09:17 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: Front Sway Bar
My RPO code sheet was on the inside of the rear storage box lid instead of the console lid.
Old May 5, 2009 | 10:18 AM
Engine: 5.0 TBI V8
Re: Front Sway Bar
Okay ill check there too, but if its not ill have to measure
Old May 5, 2009 | 10:22 AM
Engine: 5.0 TBI V8
Re: Front Sway Bar
AHA! Found it, so now what do I do. It says F41
Old May 5, 2009 | 10:48 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Re: Front Sway Bar
The safest thing to do is to simply measure the bar that you have in there now, assuming that you're keeping it.
Otherwise, you're assuming that your car came off the assembly line with the correct bar for that year's F41 package, and that it hasn't been swapped for something different in the meantime (and there's been at least 16 years of that).
Norm
Old May 5, 2009 | 10:51 AM
Engine: 5.0 TBI V8
Re: Front Sway Bar
True. I really doubt that it has been swapped because judging by the people i bought it from I dont think they would do it, but your right ill be safe and measure it anyway.
Old May 5, 2009 | 11:30 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: Front Sway Bar
If it is stock, then it's most likely a 34mm hollow. Mine was at least.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
