clicking noise on steering please help
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
hey guys i have a clicking noise when i turn my wheel while stopped or at parking lot speeds. could this be a steering column problem? because i noticed some play in the steering wheel left to right. ok thnx for any advice
Engine: LO3 305 tbi
Re: clicking noise on steering please help
I recently replaced all the steering linkages, ***** joints sway bar bushings and end links if that helps
Car: 1992 Firebird
Engine: L03 305 TBI
Axle/Gears: 2.73 posi rear
I have the same issue. A clicking noise in the steering when turning at slow speeds. Did you resolve the issue?
Car: 1992 Firebird
Engine: L03 305 TBI
The clicking sound I'm hearing sounds like it's coming from inside the steering column immediately behind the steering wheel (inside the cabin), almost as if something came loose and is rolling around inside when I turn the wheel.
Denricci22
Sep 18, 2015 09:02 AM
