quick question about removing lower control arm
Old May 25, 2009 | 11:07 AM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
do i jack the rear up so that the axle is released from pressure by jacking it up by the body or do i jack it up and support the rear axle with jack stands. let me know thanks. my instructions for my subframe connectors says one thing and my chilton book says another.
Old May 25, 2009 | 06:15 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: quick question about removing lower control arm
This is how I did it and it worked beautifully. Jack up the rear and place two jackstands on the axles lol easy as that.
Old May 25, 2009 | 06:22 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Are you trying to install LCAs os SFCs. If you are trying to replace the LCAs, I reccomend placing the jack in the center of the rear end and stands where the LCAs attach to the body. Makes getting the bolt holes realligned alot easier if you have some control over the position of the rear end.
Old May 25, 2009 | 08:56 PM
Car: 87 Camaro
Engine: 5.7 350 TPI
subframes are in and work great lcas are back on. feel free to delete this post
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
