f-body to full frame?
Old Jun 2, 2009 | 09:22 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
converting the stock chassis to full frame using channel steel, tricky? how much trouble am i looking at? and how much work for that matter? lol
Old Jun 2, 2009 | 11:39 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: f-body to full frame?
you mean kinda like sub frame connectors? what do you need a full frame for?
Old Jun 2, 2009 | 02:53 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I know that there are some guys that have done it on the vega and monza bodies but I don't know of many people doing it with the f-body cars since they are alot stronger.
They would use 2x4 steel and cut the floor boards to let it go straight through and then weld it into the subframes and the floor board then attaching a rollcage to the beams. That type of reinforcement is needed in the old H body cars because they would twist the body with as little as 500hp and break the windsheild. I guess you could consider that like a full frame because it connects the front and rear frame and everything inbetween but that is alot of work and the prep is extensive and you have to get the body checked at a body shop to make sure its not already crooked.
Old Jun 2, 2009 | 07:52 PM
willexoIX's Avatar
my dad had an f-body trans am and the frame couldnt hold up to 300 horses. almost twisted the car in half. broke it pretty much.
Old Jun 2, 2009 | 07:59 PM
Stephen's Avatar
Car: 87 GTA
What year? Musta been rusty. The stock TTAs came stock with 301 horses, on the dyno.
Old Jun 2, 2009 | 08:11 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
sounds like subframe connectors to me. get a set, and save yourself ALOT of trouble
Old Jun 2, 2009 | 08:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the car must have had some sever structural damage beforehand. I ran my car without subframe connectors for a while with a little over 500 horsepower and torque with no issues, and the car has t-tops.
Buy a good set of weld in subframe connectors and you will be good. No need to overbuild something with channel iron of all things, just adding weight for no reason.
Old Jun 2, 2009 | 08:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I installed SFC the first week I owned the car and before I took it to the track. A year later I put in a 6 point roll bar. I now have a full cage and still have the original SFC installed.
Old Jun 2, 2009 | 09:21 PM
alright these guys beat me to my suggestion. buy or build yourself subframe connectors. if you want to build them, run the tubing behind the rocker panel like the ones you can buy do. check out the link, there are tons of pictures of them installed to give you an idea of what we're all talking about. http://www.spohn.net/shop/1982-1992-...-Top-Cars.html
Old Jun 2, 2009 | 09:38 PM
willexoIX's Avatar
yea, thanks guys, subframe connectors is what i meant, oh well. im more into engines than anything else, but i guess i gotta learn sometime right? guess im gonna be on the forums for awhile, lol
Old Jun 7, 2009 | 12:10 AM
Dodgeismo's Avatar
Car: 1985 Camaro Z-28
Engine: LG4 305 c.i.d. (5.0L); 4 BBL.
Transmission: 700 R4 ; 4-spd. Auto. O.D.
Axle/Gears: 3:23 posi (CODE: GU5)
Don't ever feel embarrassed,...that's why we join these forums,..to share ideas, watch,read, and learn what we don't know so we CAN! build our dream cars. Keep reading and posting, and have fun. good luck on your project.
Old Jun 7, 2009 | 12:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
There's no such thing as a stupid question but there can always be stupid answers.
Here's your sign
Old Jun 7, 2009 | 12:23 AM
Dodgeismo's Avatar
You said it boss!...LOL...here's a stupid question,..i'm working on my signature,..how /where do i go to edit the fonts?
Old Jun 7, 2009 | 12:33 AM
Dodgeismo's Avatar
I was just kidding. What is your opinion of installing frame connectors to a 24 year old street machine? I'm planning a complete tear down/rebuild. I figure I'll install them, i've just noticed the same problem over and over again with people, is the catalytic convertor bypass issue/connector assembly strength on that end if you modify???
Last edited by Dodgeismo; Jun 7, 2009 at 12:38 AM. Reason: too short..no guts in question.
Old Jun 7, 2009 | 06:54 AM
+1 I couldn't agree more.
Old Aug 31, 2019 | 08:32 AM
Dustin Leffew's Avatar
Ed quay has rail kits for the 82-92 f bodies http://www.edquay.com/
Old Sep 19, 2019 | 10:51 PM
Wildcard0717's Avatar
I know this is kind of beating the horse, but I need some advice from the rest of the F body community. To cover the basics, a gentleman came to me a few years ago to build home a 454 worth about 550 on the dyno. Added Spohn everything to an '89 Z28. Panhard, subframe connectors ( weld in), tube front everything with coil over conversion, everything. The need for advice here comes from the fact that he had another shop fit two 60 something millimeter turbochargers with 9 pounds each. He's driven the car gently since because of his body flexing. What's the best option for stiffening the chassis up? Mind, this car does have a 6 point cage. I've never had an issue like this with cars or engines that I have built, seeing as most are NA below 600 HP
zstalker
Feb 24, 2023 10:58 AM
blakecharles
Mar 24, 2010 10:52 AM
90-irocdx3
Oct 5, 2005 01:16 AM
IrocindatZ
Sep 24, 2003 09:39 PM
85_ZED28
Jan 4, 2002 05:04 PM
