Rattle in the left rear!
Old Jul 11, 2009 | 02:21 PM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
I have a rattle in the left rear of the car forever now and its driving me INSANE! Someone said it could be the parking brake cable but it doesnt seem that it would be the problem. It only rattles when I hit bumps or rocks. If anyone has had the same problem please let me know what is was.
Old Jul 11, 2009 | 02:30 PM
Guest
Guest
Posts: n/a
Re: Rattle in the left rear!
Its probabbly the rear brake pad rattling. try and depress the brake pedal slightly next time you hear it and see if the rattle goes away from just that.
If it disappears when the pedal is pressed, you will need to remove the outside pad and bend the top tabs over the caliper tighter. i use silicone under the tabs to help elimiante rattle.
This is all assuming you have factory rear disk brakes I your 87 IROC. The fronts will do that also with the single piston Delco-Morraine calipers. its an inheret defect in design and is a common noise problem.
Dean
Old Jul 11, 2009 | 02:40 PM
Axle/Gears: Idk
Yeah i have the factory rear disk brakes, thanks i will try that.
Old Jul 18, 2009 | 02:28 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Could be the shocks.. I had a loose bottom bolt on one of mine.
Old Jul 18, 2009 | 05:00 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
have you looked under the car in that area ? ck. the panhard/trac brace bar . it's the one that runs from pass. side of rear axle to drivers side of underbody . good luck .
Old Jul 20, 2009 | 03:07 PM
GILLIGAN's Avatar
Car: 1992 RS
Engine: BLACK&DECKER AQUARIUM PUMP
Pads and cables are usally the problem but if not I had an issue with the fuel filler neck rattling in the tank. The only way to fix this if it is the problem is to drop the tank the rattle is from inside the end of the neck was hitting something I do not remember what but once the tank was dropped and the pump and sending unit removed it was obvious and I was able to fix it with a hammer and punch. Very annoying
Old Jul 20, 2009 | 08:48 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Alright. I hope the original poster doesn't mind, but can you give me some details on the filler neck issue? Apparently my gray 87 has this same issue. I can feel the filler neck rattle by shaking it, but the tank seems secure.
Old Jul 21, 2009 | 03:02 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Hey Vetruck, is the noise that comes from the front calipers a chirping/squeaking noise? That is the noise that comes form my LF wheel, and it is obviously associated with the wheels rotation, but I can't fiqure out what's causing it.
Old Jul 25, 2009 | 09:16 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I had an annoying rattle that sounds like your problem. Ended up being the end links. The bushings were pretty much rotted away and the washers were bouncing up and down when I'd hit bumps. Installed new bushings and problem went away.
Old Jul 26, 2009 | 10:39 AM
Axle/Gears: Idk
where are the end links
Old Jul 26, 2009 | 12:10 PM
The are the bushings at the end of the sway bars. They're not expensive and are pretty easy to replace.
Old Jul 27, 2009 | 12:42 AM
Axle/Gears: Idk
OK, i have figured it out. When someone first said it was the brake pads rattling, my dad said it wasnt them, so i believed him. so today after being under the car for a while, i decided to take a look for my self. and the brake pad is loose. you can stick you finger in there and push it up and down. and just to make sure it was it, i took a look at the other side and that one is really tight. so i thank all of you for your help. one more thing, how should i tighten the brake pad.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
xxx3man`
Sep 23, 2015 10:37 PM
mustangman65_79
Aug 8, 2015 12:07 PM
