Drifting
Old Jul 16, 2009 | 01:11 AM
GiovanniP98012's Avatar
Car: 1988 Camaro RS T-Tops
Engine: 2.8L V6 TPI
Drifting
I just bought my car and cant be more frustrated so far i found a faulty kill switch, Broken ignition, bad battery, completly torn up interior, awful paint, worst filters ever (oil filter hadnt been changed since 1994 and it was a dd), bad water pump, and the list goes on...
Well i fixed almost everything but the suspension is really old and worn out...
I need to redo it and im looking for a fun weekend ride so i want to know what it would take to turn one of these great cars of ours into something that can drift a little bit.
So i need help i want to know what i should replace my stock suspension with
I need
struts
springs
tierods
tierod ends
all of that kind of stuff...
Thanks in advance for helping out a new member to tgo
Old Jul 16, 2009 | 01:20 PM
Boosted1.9's Avatar
Car: 06 Corolla
Engine: 1zz-FE 1.93L lol
Transmission: c59
Axle/Gears: fwd ftl
Re: Drifting
There is a front end rebuild kit on Ebay that is 250$ shipped, i purchased it...it is all mquay norris (sp) parts and comes with tierods balljoints draglink tierod sleeves bushings swaybar endlinks idler arm and a couple other things, all in all the kit appears to be great in quality and from the reviews i have personally read it performs great. And for it being a name brand, and as inexpensive as it is its simply a steal (i added it all up via advanced auto and its a little over 425$ for everything the rebuild kit comes with) and as for struts/springs i dont know i havent decided which route to go with them yet :P
Old Jul 16, 2009 | 01:28 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Re: Drifting
the best upgrade to make you car handle better is a good set of shocks and struts. Koni and Bilstein are about the best but KYB and other name brands will do alrite. Next you would want to invest in some lowering springs from Eibach or maybe just some IROC or GTA springs, do the same with the roll bars try and ****** a pair off a GTA or IROC. If your steering feels loose then i would buy the kit mentioned above. Lastly some Polyurethane control arm bushing would really help in what you tryin to achieve, and if your trying to drift on the street then thing twice i smashed my first third gen that way.
a posi-traction rear differential would definetly help too
Old Jul 16, 2009 | 01:30 PM
Engine: 2.8L V6 TPI
Re: Drifting
Can you send me a link to it all i can find is for 67's and that model year...
Maybe im an idiot and that works for our car too but im just a little confused haha sorry, thanks for the help
Old Jul 16, 2009 | 01:36 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Re: Drifting
nooo i reallly really doubt a kit for a 1st gen will work for a 3rd gen
Old Jul 16, 2009 | 01:38 PM
Boosted1.9's Avatar
Car: 06 Corolla
Transmission: c59
Axle/Gears: fwd ftl
Re: Drifting
http://stores.shop.ebay.com/ADEALS-T...__W0QQ_armrsZ1
there are 2 different kits for thirdgens 82-86 and 87-92 you call call and order and he will ship them same day if its not to late
Old Jul 16, 2009 | 01:39 PM
Engine: 2.8L V6 TPI
Re: Drifting
Where should i go about finding KONI shocks for a decent price?
Any special brand to look for on the control arm?
And im not really trying to drift on the streets i just want to get my DD to be able to drift when i have a good opertunity, haha nothing better then making little imports feel stupid when you slide a car that cost half as much the same way :P
Old Jul 17, 2009 | 02:54 PM
1988-305-tbi's Avatar
Re: Drifting
SFCs
Old Jul 17, 2009 | 03:34 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Drifting
Originally Posted by 1988-305-tbi
SFCs
Also snag a wonderbar ($50) and a Strut Tower Brace ($40) That will stiffen up the front along with the subframe connectors.
I would also either get a limited slip rearend or a get a mini-spool (locks both tires)... That would be the perfect start.
Old Jul 20, 2009 | 01:49 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Re: Drifting
i myself do not know were to find KONI's for a good price because i myself have KYB's because the KONI's were out of my price range. So your asking the wrong person.
Old Jul 22, 2009 | 06:08 PM
kevinc's Avatar
Car: 1982 Z28
Re: Drifting
I'm clearing out a few sets of springs in the Classifieds that might be of use, including brand new Hypercoil 800# fronts, used Hypercoil 225# and Blue Coil 175# rears.
dustint209
Nov 26, 2015 12:28 AM
ULTM8Z
Oct 2, 2015 01:25 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
vrooom305
Sep 17, 2002 07:42 PM
REVLIMIT
Theoretical and Street Racing
Mar 5, 2002 10:07 PM
