I can't figure the problem out!
Old Jul 16, 2009 | 04:03 PM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
Ok, i have been asking questions about the rattle on my car. It's not the brake pads, I have checked the bushings and bearings under the car and all of those are working fine, and also bolted down the inner fender panel. The quarter panels are secure. I bounce the car up and down in the back, and i dont hear anything. The left rear rattles a lot on our gravel road, i open the door and stick my head out, and its clearly something in the left rear. It sounds like something just dangling or metal-to-metal rattling. I'm only 17 and don't know how to work on suspension, and i don't want to take it to a repair shop and pay a fortune to get something fixed that does not affect the car. Its the only problem i have with the car. It would much more peaceful in the car if i did not have to hear that rattle.
Old Jul 16, 2009 | 04:08 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Re: I can't figure the problem out!
did you check the top shock bushing? (inside and under the car)
Start simple and cheap - first
Old Jul 16, 2009 | 04:11 PM
Axle/Gears: Idk
I can't reach up in there. Do you have to take out the rear seats to get to that?
Old Jul 16, 2009 | 05:12 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
check the panhard/trace brace bar . on one of mine all 3 bolts had fallen out . made a heck of a rattle . the bar runs from the pass. side of rear axle to the body on drivers side under the car . the bolts are metric , 15mm head as i recall . good luck .
Old Jul 16, 2009 | 06:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its not the door handle is it?
check the exhaust, hangers, tailpiipe.
sway bar mounts
Old Jul 16, 2009 | 07:06 PM
Axle/Gears: Idk
ok, i just looked at the top rear shock mount, and the bushing was bad. i fixed it, and that still didn't fix it. its somewhere in the tire/brakes/rim area. its soo freakin annoying.
Old Jul 16, 2009 | 07:07 PM
Axle/Gears: Idk
i was wondering, maybe if the top shock bushing is bad, maybe the bottom one is too. how can you tell if the bottom one is bad?
Old Jul 16, 2009 | 07:08 PM
Twin_Turbo's Avatar
Have you checked the license plate frame? I know mine makes a rattling noise over rough roads. Sounds metallic.
Old Jul 16, 2009 | 07:24 PM
UNCLE TOM's Avatar
have you checked this ???
Old Jul 16, 2009 | 08:01 PM
Axle/Gears: Idk
ok, i totally forgot about this. this will probably narrow it down a lot. it does not rattle when i drag the brakes. say 10 mph normal-it really rattles. 10 mph plus dragging brakes-no rattle.
Old Jul 16, 2009 | 08:23 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Did you check the sway bar end links?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
