HELP!!! Brand NEW rear suspension springy
Old Jul 24, 2009 | 02:16 PM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
Transmission: TH350, B&M shift kit, Huges 3000 sc
Axle/Gears: 3:23 Posi
I just did a complete restoration on my 87 Iroc, I installed a NEW suspension all around, New KYB GR-2, swaybars, wonder bar, A-arms, Control arms, Panhard bar, torque arm, end links, and EVERY bushing. My problem is the REAR is springy and sags a bit and the front seems the correct stiffness. Why is the rear soo soft? It almost seems like the BRAND NEW shocks in the rear are bad Is there something I am over looking?, Is this normal with the GR-2s? ANY HELP would be GREAT! THANKS.
Old Jul 24, 2009 | 02:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: HELP!!! Brand NEW rear suspension springy
You don't mention replacing springs, which have more to do with sag than shocks.
JamesC
Old Jul 24, 2009 | 02:46 PM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
I swapped a set of 91 V8 springs with my 87 ones because I was afraid of that. The 91 srings I had powder coated, Thats horrible to just chuck them if that is the case. I should have kept the originals.
Old Jul 24, 2009 | 02:53 PM
JamesC's Avatar
I suspect that the IROC springs were far stiffer.
JamesC
Old Jul 24, 2009 | 03:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Springs are funny, original ones can last near forever if the shocks are kept in good shape. Them 91s could of been on a car with blown shocks for to long.
Old Jul 24, 2009 | 03:15 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
You said '91 V8 springs, but what model? That could influence the spring rates Ex: WS6, FE1, etc.
Old Aug 5, 2009 | 06:42 AM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
I think that may be the case, I have decided to drop her. I ordered a set of AG lowering springs (1.6 rear, 1.4 front). Is there any other mods I need to do when I install the springs? Or will they go right in? THANKS!
Old Aug 5, 2009 | 10:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The springs will go right in, but dropping that much may require an adjustable panhard rod to recenter the rear end. I used an Eibach ProKit (only 1" drop), and I used an adjustable panhard to recenter my rear end.
Oh - and don't expect to actually see the car drop 1.6 in back there - the new 'lowering springs' will actually be longer (ie taller) than the old sagging OEM springs when the weight is set back down on them.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
