best spring and shock combo for auto x
Old Aug 3, 2009 | 11:03 AM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
i want to know what setups you auto x guys are useing on your thirdgens and other suspenison parts like strut bars sfc's ect. i am looking to get into auto x and want some 1st hand knowledge
Old Aug 3, 2009 | 02:01 PM
1988-305-tbi's Avatar
Re: best spring and shock combo for auto x
SEARCH
Old Aug 3, 2009 | 03:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
figure out what class you want to run in, then get the rules for that class and see what you can actually do. No point buying a pile of parts if they will make you illegal.
Old Aug 4, 2009 | 02:42 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
As long as you don't switch to a coil-over setup, most shocks are allowed in any class. My Konis can be used in the SCCA stock class, but my springs can't. Springs on the other hand are way different. If it isn't a direct stock replacement it won't be allowed in the stock class. Any lowering springs or stiffer then stock springs will bump you up.
Are you going to be running with the SCCA?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F-body driver
Mar 6, 2023 11:44 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
SG91camaro
Sep 5, 2015 10:27 PM
z28guy134
Sep 1, 2015 11:50 PM
