Strut Bar For A 4Bbl 350?
Old Aug 25, 2009 | 01:11 AM
shouldahadav8's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 350 4bbl
Transmission: Stock Auto
Axle/Gears: Stock
Hello all,
Recently I've been in the process of trying to tighten up the suspension and chassis of my car, preparing it for some local rally-cross and cone-killer events coming up.
If you've seen some of my earlier posts, you know that I've lowered and tightened the springs and shocks, got a panhard rod and control arms with relocation brackets, procured a wonderbar (thank you badbob66), and threw some cash down on falkens all the way around.
Next I wanted a strut bar, the bar that runs across the top of the engine connecting the strut towers together. The problem I run into is the fact that I'm a lone wolf running a 4bbl 350 and I cannot seem to find a bar made for my car (every one I dig up is made for TPIs) and they won't work with my current setup (carb, air filter, etc.)
If someone could point me in the right direction, maybe throw a couple URL's my way, I would be eternally in your service! Thank you!
Old Aug 25, 2009 | 01:46 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
Re: Strut Bar For A 4Bbl 350?
Here you go:
http://www.jegs.com/i/Edelbrock/350/5227/10002/-1
I saw that one on a camaro with a 4 barrel in an issue of chevy high performance maybe a year ago.
Old Aug 25, 2009 | 02:08 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
The only problem with that one is that it is crap. It might as well be a 2-point. I'm sure it keeps the strut towers an equal distance apart, but it doesn't keep the strut towers from folding in towards the firewall, since the mounting brackets on the strut towers are weak and just bend under braking. Vetruck mentioned this in another thread, and I've seen a bent one in person.
Old Aug 25, 2009 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A pic of my Edelbrock can be seen below in my Car Details. A V-belt system with the AC compressor on the driver's side will have a brace that interferes with the strut-to-strut bar. No problems with a serp system.
JamesC
Old Aug 25, 2009 | 10:19 AM
Engine: 350 4bbl
Axle/Gears: Stock
Camarslow,
Thank you so much! That is exactly what's I'm looking for!
gregsz-28,
I appreciate your concern. I see what you're saying with the way the metal is bent, but I think this is better than nothing if I have no other options. Could you perhaps point me in the direction of the thread you're referring to?
JamesC,
That looks incredible! Not only the strut bar, but the whole car. This is a work of art, and I'm sure you're very proud of it!
If anyone has any other links, maybe to one without as many bends, it would be greatly appreciated! Thank you!
-shouldahadaveight
Old Aug 25, 2009 | 10:32 AM
JamesC's Avatar
Originally Posted by shouldahadav8
JamesC,
Many thanks.
JamesC
Old Aug 25, 2009 | 11:17 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Hello all,
i have a strut tower brace from mac performance, it is a 2 point strut tower barce and it bolts directly to the shock tower bolts, no drilling ,,,it is chrome and is beautiful and solid, i have a 350 with edelbrock carb and round style air filter and it doesn't come close to it at all...i also have a wonder bar and SFC underneath, the car handles like crazy!..there may be people with a 3 point tower bar, but really think it's overkill...if you bend this bar , i think you have other serious issues with the car,,good luck.
Old Aug 25, 2009 | 12:23 PM
Engine: 350 4bbl
Axle/Gears: Stock
Is there a chance you could post a picture of your strut bar? I cannot decide between a 2 or 3 point
Old Aug 25, 2009 | 12:24 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Post #57
https://www.thirdgen.org/forums/fabr...t-tower-2.html
Old Aug 25, 2009 | 12:29 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If you want to buy an aftermarket strut bar, go with a 2 point. The Edelbrock one is the only 3 point that will fit your car, and the extra material on it to make it a 3 point isn't worth the weight it adds to your car, unless you modify it.
Old Aug 25, 2009 | 12:55 PM
JamesC's Avatar
I like the three-point Edelbrock for its fit and finish. Moreover, the front end seems more stable (and I'm running spherical strut mounts, SFC's, and a steering box brace). That said, I don't drive the car hard.
At any rate, read the entire link above. It's informative and something from which you can base your opinion. One thing I wonder about Vetruck's experience is the speed(s) he was using and how that speed might affect the mounts' performance.
JamesC
Old Aug 26, 2009 | 10:54 AM
Engine: 350 4bbl
Axle/Gears: Stock
JamesC and gregsz-28,
Thank you both for the wealth of information provided! I'm reading up on the link provided now so as to make an informed decision in regards to purchasing a strut bar.
The courses I will be running do not allow for high speeds to be reached, maybe fifty tops, but are more about traction and control. I am taking this all into account before I purchase.
I had one more question though: On the three point, where does it hook up to beneath the windshield?
Thank you!
Old Aug 26, 2009 | 11:00 AM
JamesC's Avatar
Post #18 of the following link has a pic or two that should answer you question:
https://www.thirdgen.org/forums/susp...-3-pt-stb.html
JamesC
Old Aug 26, 2009 | 12:15 PM
Engine: 350 4bbl
Axle/Gears: Stock
JamesC,
I cannot tell you how informative and quick to reply you have been. You have made this process simple and easy, and I cannot tell you how thankful I am.
However, that does not mean I'm done barraging you with questions
Is there any work that needs to be done besides the drilling of the mounts under the windshield?
I believe I read something about having to modify the underside of the hood to fit the brace. Is this true? I have the stock Trans Am hood installed right now. But in your pictures, it looks like your brace (the Edelbrock, i believe) sits lower than your air filter. And my air filter has no clearance problems.
Also, where did you get your air filter top?
I'm using the plain chrome one the previous owner installed, and I wanted one that read '5.7 H.O.' just like yours. Hope you don't think I'm trying to copy you!
Thanks!
Old Aug 26, 2009 | 12:23 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Trans ams have lower hoods than Camaros, so you may need to modify your hood.
Old Aug 26, 2009 | 12:47 PM
Engine: 350 4bbl
Axle/Gears: Stock
gregsz-28,
How would I go about doing this?
Old Aug 26, 2009 | 12:56 PM
JamesC's Avatar
Stephen, who has a bird, mentions having to mod his hood. You might PM him for the particulars.
I had a print shop make the 5.7 H.O. decal for me.
JamesC
Old Aug 26, 2009 | 11:42 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
gregsz-28,
IDK, I never had a 'bird.
You might just need to dent or cut the underhood bracing a bit, but I agree with James, ask someone like Stephen.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
Eric-86sc
Aug 24, 2015 09:01 PM
