Broken at the A-Arm
Old Sep 26, 2009 | 04:30 PM
92RSDailyDriver's Avatar
Car: 92 RS
Engine: 305 TBI Stock
Broken at the A-Arm
Got a question for you guys...
I bought a really nice looking 92 RS Heritage Edition (so I thought)
The car was bought as kinda a father son project, he is 13 and i'm trying to teach him about cars. We pulled the 160,000+ 305 to put in a fresh 350 and convert it to a stick instead of an auto (got 3 years till he can drive thank god).
Here is my problem, after getting under its skin I found out it has been wrecked pretty bad in the front drivers corner. After looking at the sub-frame where the A-arm bolts to it, it has a crack almost all the way around the bracket. Would you guys recommend welding it or replacing the sub frame?
thanx
Old Sep 26, 2009 | 04:37 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Broken at the A-Arm
Well, is it broken at the rear or front mount? If it's at the front then it mounts to the k-member and you can replace it with an aftermarket one and shave 60lbs I think. If it's the rear mount then in all honesty your screwed. Subframes on these cars aren't like the older ones, unless you REALLY know what your doing it's almost impossible to take them out. A pic would help, you could probably weld it, if not you could cut the piece out and replace it with one from a donor car, but you might have alignment issues if you do so.
Good luck
Alex
Old Sep 26, 2009 | 04:51 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Let's see a pic, sectioning in a piece is not that hard, welding/and bracing it could be an option? Alignment issues could arise if not done properly..Need a pic...
Old Sep 26, 2009 | 05:42 PM
Twin_Turbo's Avatar
Good luck
Alex
What are you talking about? Both A arm mounts are on the subframe:
The entire gray thing is bolt in:
Old Sep 26, 2009 | 07:24 PM
Car: 92 RS
I'll get a pic up 2moro, wife apparentely hid the camara from me.
it is the back (on the front side of the mount), where the factory weld attached it originally
I used the picture above to show you where it is till I can get a pic 2moro
Never had to deal with any frame issues before.
Thanks for the replies
Old Sep 26, 2009 | 07:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the crack on the k-member can be welded, but make sure nothing else is damaged.
you can usually find new factory kmembers cheap.
or go aftermarket, buy they can get a little pricey, about 500$
Old Sep 26, 2009 | 09:51 PM
Car: 92 RS
I was hoping to be able to get it welded but after looking at it closer i don't know, the crack goes almost all the way around. Good thing I decided not to tag and drive the car until we put the motor in or I would never have noticed it untill it was too late.
Old Sep 27, 2009 | 01:53 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I've got a sub-frame from an 85 TA ready to drop. I'm in MS so shipping shouldn't be too bad.
Kevin D.
Old Sep 27, 2009 | 03:48 PM
Your right, for some retarded reason I was thinking of my nova. But the gray thing in the pic is the k-member. I always thought the subframe meant the rails. Maybe I'm just crazy.
Old Sep 27, 2009 | 10:26 PM
Car: 92 RS
Kevin D.
After looking real close at how far around the crack goes, I would definately have to remove it to repair it. since it has to be removed I will replace it. Possibly got one coming from a buddy if its not damaged (car's been rolled) If that don't work out, what would you want shipped to 37766? I could use my work addy if it needs to be a business
Donny
Old Sep 30, 2009 | 08:42 PM
shr00m's Avatar
$40 plus shipping. Couldn't tell you what that is untill I get it off.
Kevin D.
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
