solid motor mount help
Old Sep 27, 2009 | 10:15 AM
8550ta's Avatar
I installed a set of jegster solid motor mounts while I had mey new engine built and now I am trying to set the bad boy in and the mounts wont align.
I can get a bolt through one side no problem but then the other side is a good inch off.
Is it possible that I am using the wrong bolt holes on the frame pads? I used the same holes the stock mounts used.
Old Sep 27, 2009 | 11:58 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: solid motor mount help
I dont believe jegster mounts will work on a 3rd gen with the factory engine side clambshell.
Old Sep 27, 2009 | 12:19 PM
Demon355's Avatar
Will solid engine mounts make the motor sit lower in the car? They hard to install?
Old Sep 27, 2009 | 12:26 PM
8550ta's Avatar
Well I am not using the clamshell mounts (although I tried them too)
I am using these mounts and pads
http://www.jegs.com/i/JEGS/555/50521/10002/-1#
http://www.jegs.com/i/JEGS/555/50511/10002/-1
Old Sep 27, 2009 | 02:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
hmmm i dont see why they wouldnt fit. Is there a left and right engine side mount like stock? thats all i can think of.
Old Sep 27, 2009 | 04:57 PM
8550ta's Avatar
Nope the are the same so it shouldnt matter what side they are on.
I dug into this some more and compared the stock mounts that came off the car and they semm to have worn down to make the distance between the engine and chassis smaller. I then went to Autozone and compared a new stock mount with the engine mounts, and when I bolted them together they distance between them were identical to the new solid mounts.
So now it seems like I just need to do some more coaxing to get them to fit...................... or my K-member is bent and sandwiching the two mounts together. This is becoming a major pain in the rump.
Old Oct 4, 2009 | 09:45 AM
8550ta's Avatar
Well I had Jegs send me another set of mounts and come to find out that there are a drivers and passenger side for these cars. My first set contained a set of two drivers side, which prevented the mounts from aligning
Old Oct 6, 2009 | 11:51 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
dont you hate it..
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
