4th GEN SUSPENSION???
Car: 91 camaro
Engine: LS3
I am swaping out my motor for an Lt1 and was just trying to see if I could use the whole front suspension out of the 4th gen to put in my 3rd gen. also wanna make sure that the rear end will bolt in??
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: 4th GEN SUSPENSION???
The rear will bolt in, it's just wider than the 3rd gen rear so you wont be able to run 3rd gen wheels, you will have to run the 4th gen wheel or ones with similar offset. If you have an 82-83 car the brake line fitting for the rear is different, but 84 and up hooks right up.
As for the front suspension I dont know for a fact, but I am going to say no. Or at least not without alot of modification because the spring/strut are one component on a 4th gen where the 3rd gen the shock and spring are seperate. The lower control arms are different. I'd guess the only way to make it possible would be swap the whole K member in. Don't know if that's possible.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
There would be much fabrication requied to use 4th gen front suspension, too much work and not much to gain, IMO.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Car: 87 GTA
Stock 3rd gen wheels SIT out further, but do not STICK out. They are still under the fender. Blue Camaro, 4th gen rear end, stock 16" wheels.
I've never heard anyone say it looks bad, except the ones that do not understand & assume things incorrectly.
Car: 92 zo3 z28
Engine: LT1 w/lt4 hotcam kit
Transmission: stage 3 700r4
Axle/Gears: posi 3.42
has any one had problems with the tires rubbing on hard turns or hard bumps.its doin it on mine bad and i used the stock 3rd gen springs but i put a set of kyb gr2 shocks on the back.
Car: 91 camaro
Engine: LS3
yea I have 20 inch rims in the back and it was rubbing, I solved it by cutting the part of the body that folds in the wheel well... I would suggest you have someone do that for you if that was your problem.
My deepest apologies. As I do not have personal experience, I have heard/read of people having issues with the tires hitting the fender lip when you hit bump or turn at times, even more so being a problem if the car is lowered.
Car: 87 GTA
That comes from how a stock panhard bar works.
Since it swings in an arc, as the suspension goes up or down, it shifts left to right some. As a car gets lowered, the center of that arc gets "pushed" to one side, making one side even closer than before.
At stock height & good bushings, my rear axle was off by almost a full inch. Am adjustable PHB fixed that.
Car: 92 zo3 z28
well my car isnt lowered and i have the stock z28 wheels on it. the only thing thats not stock is the adj. torque arm. and as far as a adj. phb goes im not sure how it wuld solve the problem if the only difference between a 3rd and 4th gen rear is the width as far as i know.
Car: 87 GTA
Is the 4th gen extra width outside or inside the PHB mount? If it is inside the mount, I could see the adjustable PHB a MUST.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
WRONG. I can't believe how often this totally inaccurate information keeps getting passed around.
Car: 87 GTA
If you run stock 3rd gen wheels I agree for the most part; the 8" wide stock 3rd gen wheel appearance is subjective, the 7" wide wheels look fine. However, if you run a wider wheel (intended for 3rd gens than switch rear ends) it looks bad and does stick out a lot. Skateboard look to be exact.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
My 2000 Z28 sure didn't have coil-overs from the factory. Separate springs and struts and I sold them to a 3rdGen owner when I replaced the factory stuff with some Eibachs/Strano-Bilstiens. The K-member and A-arms, I'm not sure about...
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Went to a yard sale where there was a smashed up 98 Camaro RS. Will that rear fit our 3rd gen cars? I did a google search and found some site that said only 93-97 4th gen rears would work in 3rd gen's. Anyone confirm this? Should it have the 342's still, & does it matter if it was 5 speed or auto? Looked like a good set up. Still had the calipers and all. Bet I could pull it myself, and get it for about $100. Im not sure of the motor size since it was gone.
Car: 87 GTA
Not only is that exact same question asked WEEKLY, the is a STICKY that addresses that question!
Car: 89 RS
That's messed up man. Not like we are talking head lights, & this is a new thread! So tired of that search bs. If ur upset I clutter the threads up then stop posting about being pissed about it! At least im asking info, and not just being a D.
Car: 87 GTA
Instead of using the search feature that the Moderators have provided & being self-sufficient, you want everyone else to hand you every little bit of info you want? THAT is what is messed up!
You would rather clutter the Forums, asking a question that is answered WEEKLY?
Sure...I coulda just given you the answer & made my life easier. But tomorrow, you'd be back here asking ANOTHER question that has been answered a million times.
The sooner you learn to help yourself, the less of a burden you'll be on everybody else here.
Car: 89 RS
Car: 87 GTA
Just dont know how to stop do u. Well since u know it all guess we dont have to ever start another new thread. Just mail u or search then. Right? Its all been asked before dude. For ur info, doing a search is how I found this thread. Little did I know that thirdgen.coms very own Barney Fife was lurking in the bushes.
I'm not the only one who feels this way, just one of the most vocal about it.Stick around long enough, and you'll get sick of reading & answering the same stuff over & over & over &.....
Car: 89 RS
k well sorry dude but on the other hand its a real bi when ur searching for an hour & come up empty. Like i said I tried google too. this was one where it may be a sticky, & in that case it sucks if it dont come up in a search. 4 sure thats not my fault.
Guest
Posts: n/a
4th gen front suspension? You might as well just sell your 3rd gen and vuy a 4th gen if that is what you want.
The 3rd gen is a front strut platform, I will not even begin to deal with the troubles you will have to overcome modifying one into a 4th gen double arm setup.
4th gen rear suspension? Basically the same other than the axle is wider from mount face to mount face of the wheels. larger is heavier= more unsprung weight=bad.
Car: '88 GTA
Engine: L-98
Looks like total crap.
