Dropping Car 1.5 Inches
Old Nov 16, 2009 | 09:46 PM
lbarile1991's Avatar
I have a 1983 Trans Am and have been thinking about dropping the car 1.5 or so inches. I was planning on buying a 1 inch lowering springs and cutting some of the spring off. I would like to know if I put these springs in will I have to do anything else? Will my ride down the road be bumpier? Any tips or suggestions on dropping my car would be greatly appreciated.
Old Nov 16, 2009 | 09:53 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: Dropping Car 1.5 Inches
Why dont you try taking out the spring isolators. That should drop an inch or so you might find its all you need. Or you could go with "weight jackers" they're pretty neat, do a search on them.
Old Nov 16, 2009 | 09:57 PM
Stephen's Avatar
Car: 87 GTA
For just 1.5", other than an alignment, nothing more should be needed.
After putting on weight jacks & dropping mine 2", my alignment (before) was so bad, it actually got BETTER, after dropping the car!
Unless your springs are worn already, why not just cut your stock springs, instead of buying new ones & cutting those? I've cut springs before & used the cars for autocross. If you cut them right (saw, no torch), they'll still be perfectly fine afterwards & save you money.
Old Nov 16, 2009 | 11:27 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
.Just trim your stocks. Or buy some stiffer front Moogs like I did and trim those for firmer handling. Rears are real easy to pull out, isolators may only give a 1/2 inch so try that first then possibly trim those too. Later.
Old Nov 16, 2009 | 11:50 PM
Where can I locate these isolaters? and I have to pull the springs out to cut them correct? So if I do decide to cut the springs I should get an alignment correct?
Old Nov 16, 2009 | 11:54 PM
Stephen's Avatar
Car: 87 GTA
The isolaters are between the springs & the body. Some people put them back in, I never have.
To cut the spring RIGHT....Yes, you hafta pull them out. But the rears are SIMPLE. Even the fronts aren't nearly as hard as people complain about. I did all 4 corners & only took the 4 wheels off, 2 nuts & 2 "bolts" (large screws really) loose!
Old Nov 16, 2009 | 11:57 PM
Stephen's Avatar
Car: 87 GTA
To save your tires lifespan, most likely you'll want an alignment. My fronts are already almost worn out, so I haven't bothered getting a front end alignment. But will when brand new tires go on.
Old Nov 17, 2009 | 08:00 AM
UMI Sales's Avatar
Hello
I always suggest anytime a vehicle is lowered to look into a adjustable pan hard bar to allow you to re center the rear end under the vehicle. Below is a link to show you what all UMI Performance has to offer! And I would also suggest eventually looking into a set of lower control arm relocation brackets to allow you to locate the control arm so that it is parallel to the ground. And it will gain back your traction that you lost when the vehicle was lowered.
http://www.umiperformance.com/catalo...i95s2dvqq70j86
If you have any other questions feel free to ask and I will be more than glad to help.
Brad
Old Nov 19, 2009 | 09:40 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Don't forget shocks when lowering the car.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Kaweh
Aug 9, 2015 02:54 PM
