Installed lowering springs on my sons GTA - HELP !!
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
Like the title reads, we install a set of lowering springs on my sons 87 GTA this weekend and it came out looking like crap !
The springs were 1.75 drop all the way around and the result..... the front tire to fender gap went from about 4" to next-to-nothing ! And the rear didn't even change.
Except for the shocks, I've rebuilt the entire front suspension and installed new bushings on the rear swaybar.
Any ideas ??
Any ideas ??
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Installed lowering springs on my sons GTA - HELP !!
did you install the front and rear springs on the wrong end? ie, fronts in rear and rears up front?
Engine: 5.0 TPI
nope, there's no confusing that.
I just spoke with the spring manufacturer.... they sent me the wrong front springs. They'll be sending me another set, hopefully.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What about the rears? You say they are the same as stock? Maybe you need to drive around a bit and have them settle in.
If you installed the eibach pro kit in the rear, they don't drop the rear a bit, if your old springs are sagged they may even raise the car. For the fronts, did you install the isolator? You could order a thicker urethane one if needed. They are commonly sold for mustangs, i have used them on other cars with good results.
Car: 1990 Chevy Camaro IROC-Z
Transmission: TH700r4
Axle/Gears: 3:73:1 posi
what brand were the springs cuz i did the same 1.75" with the same result on my 90 IROC
sailtexas186548
08-26-2015 03:32 PM
