cleaning the underbody need help please.
Old Dec 21, 2009 | 02:35 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
hi i wanna clean my camaros underbody just so it looks nice and im not exactly sure how to do this. well first of all the under body has rust covering it all over and im not positive but it looks like its just a thin coat so could i go over it with brushes and dawn and a strong source of water will i be able to get this rust off? or is it more then that?
and say if i cant get the rust off can i go over it with that stuff that i belive is called por-15? how much is this stuff and how much will i need brushing it on? do i just buy this at say shucks?
please help me out here thanks i have a couple pics below. once i think of it i might only have rust on the pipes or mostly just on them. the car sat outside for 5yrs in oregon with no cover and it only have 27k miles on it. i will get better pics of it when i get her on jackstands. thanks for the help.
Attached Thumbnails cleaning the underbody need help please.-maro-031.jpg   cleaning the underbody need help please.-maro-032.jpg   cleaning the underbody need help please.-maro-033.jpg
Old Dec 21, 2009 | 06:14 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: cleaning the underbody need help please.
When we were restoring our Torino.. We rented the big power washer from Home Depot, it was a trailer, I don't remember how big it was, but it was huge, 18 horse or something.. We jacked the car up, sprayed it down with a bunch of Castrol Superclean, and hosed it down, we made a shorter tip, it was enough to remove undercoating..
Old Dec 21, 2009 | 01:23 PM
brutalform's Avatar
A lot of the stuff I see is not rust, but undercoating. You might want to look into getting some form of remover. I had done my previous F body with Brake Kleen, a lot of rags, and something to protect your lungs, like a respirator.
Old Dec 21, 2009 | 03:34 PM
Engine: 305TPI
thanks do you know how much it was to rent 1? if i do remove the undercoating do i need to use bed liner or that por-15? thanks
Old Dec 21, 2009 | 03:36 PM
Engine: 305TPI
so if i get the undercoating off what do you reccomend to apply to protect the underbody? and if i rent a powerwasher how long do you think it will take me to get everything finished properly? by my self.
Old Dec 21, 2009 | 05:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I wouldn't remove any under coating stuck on well.
Id call some auto detial shop and get quotes on a under side clean.
Once ya add in everything plus the time, it might be cheaper.
Plus they will have a lift to really get under it good.
Old Dec 22, 2009 | 03:12 AM
Engine: 305TPI
well see i was just going do it to spare some time and i just like keeping everything clean and i just like the experience. i might not do the full job and maybe just do a good washing under there but i would like to do the complete thing.
Old Dec 22, 2009 | 03:22 AM
Twin_Turbo's Avatar
Underbody comes off with kerosine, much cheaper than brake clean and a little safer too (not as flammable) it'll stink pretty badly though.
Here's my before & after:
the brown stains on the left are from an exhaust cut out (bad idea)
After some bedliner it's all nice & clean, won't rust and not sticky like underbody spray.
Old Dec 22, 2009 | 03:30 AM
Engine: 305TPI
thanks that looks really good just asking how long did it take you and how much did you spend? i dont wanna go anymore into the hole lol.
Old Dec 22, 2009 | 01:36 PM
Twin_Turbo's Avatar
Stripping the car was the most work, cleaning it took a day, painting the underside another half day. Only cost me a couple of gallons of kerosine, some rags and the bedliner and seam sealer I used everywhere. Less than 100$ for sure.
Old Dec 22, 2009 | 01:40 PM
Engine: 305TPI
thanks i think i might just clean under neath and not do the stripping and all because i just dont have the money to spend on all that. thanks though.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
TheExaminer
Sep 28, 2015 02:28 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
