Front coil spring on V6 and V8
Old Jan 6, 2010 | 10:08 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
What the inside diameter of front coil sprints on a '92 V6 and V8?
From some sources I heard that the values are different, so a V8 coil spring wouldn't fit in a V6 lower control arm. But I checked the values on rockauto and it gives the same inside diameter for both 3.1 V6 RS and 5.0 V8 Z28.
Old Jan 6, 2010 | 04:27 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Front coil spring on V6 and V8
the diameters are the same. either springs will fit either car (motor application). the difference is spring rate. the v8 will use a "heavier" spring rate. stock spring vs stock spring, the v8 spring into a v6 car will raise the front of the car, and be stiffer.
Old Jan 7, 2010 | 12:40 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
I'm in the planning phase of a V6 to V8 swap.
Based on your reply it's enough to change the front to V8 springs and they will fit perfectly to the current V6 front.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
