wounder bar
Old Dec 23, 2009 | 03:38 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
wounder bar
I bought one off here awhile back and its now time to install but, all i got is the bar itself. is there anykind of brackets i need and does someone have an installed pic i can see?
Old Dec 23, 2009 | 04:04 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: wounder bar
no brackets needed. if u dont have some one to help you be sure to use a jack to support the weight of the front sway? bar? its quite heavy and hurts lol. install is pretty simple. unbolt 4 bolts put wonder bar in between frame and sway bar brakets, bolts every thing back up.
Old Dec 23, 2009 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: wounder bar
http://www.top-downsolutions.com/Doc...structions.pdf
JamesC
Old Dec 23, 2009 | 08:44 AM
Chezoom's Avatar
Engine: LO3, LG4
Re: wounder bar
thanks guys
Old Dec 24, 2009 | 02:38 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: wounder bar
Originally Posted by JamesC
He can follow my instructions, but if it isn't a TDS steering brace it won't have the extra pair of bolt holes that make installation easier.
Lon
Old Dec 24, 2009 | 03:40 AM
Chezoom's Avatar
Engine: LO3, LG4
Re: wounder bar
well this was easier than i thought! had a friend help me. took 25 min tops.Man what an improvement!!!!! highly recomend it!!!!!!!!!!!!
Old Dec 25, 2009 | 08:59 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: wounder bar
thanks guys
Put a bandaid on that wounded bar...or are you talking German with "wounderbar"
Old Dec 28, 2009 | 11:43 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: wounder bar
Old Dec 30, 2009 | 02:22 AM
Chezoom's Avatar
Engine: LO3, LG4
Re: wounder bar
Originally Posted by racing geek
say what?
Old Jan 6, 2010 | 10:23 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Re: wounder bar
say what?
I wasn't aware there was any "improvement" you could really feel with the wonder bar.... its main purpose is to stiffen the crack prone steering box area of the frame.
Old Jan 7, 2010 | 06:02 AM
DJP87Z28's Avatar
Re: wounder bar
"improvements" are a must because you do not want to WONDER why you spent the money.
Old Jan 7, 2010 | 06:15 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: wounder bar
Our front ends have alot of flex, the Wonder definitely makes the front end more rigid and the difference can be felt. I can not imagine driving my car w/o one!
Old Jan 7, 2010 | 06:27 AM
JamesC's Avatar
Re: wounder bar
If you feel an improvement, the area that the steering box brace BandAids, is probably already torn/weakened. At any rate, the Wonderbar question and its significance is an old one. A lot of info about the brace and its effect can be found in the following link:
https://www.thirdgen.org/forums/susp...questions.html
JamesC
Old Jan 7, 2010 | 06:35 AM
J91's Avatar
J91
Re: wounder bar
JamesC
I have checked my frame again and again in the steering box area, it is solid as can be, it's an Arizona car and very clean underneath. After driving the car w/o the wonderbar and then w/it, I noticed an improvement, especially in hard cornering situations.
My 87 IROC had one and after driving the 91, I felt the 87 handled better, so I took the wonder bar off of the (smashed) 87 and put it on the 91. I still feel the best improvement to a third gen is SFC's...
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
