torque arm problem
Old Jan 15, 2010 | 10:51 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
torque arm problem
well i pulled out of the driveway and heard a noise like something scraping let off the gas heard a clunk so i turned around since i wasn't half a mile from the house. After going over everything i come to the front torque arm mount, bolt was out but still in the clamp. So i finally get it back in and it wont tighten up, so whoever put the poly mounts on my car was a ****ing moron and over tightened the bolt that goes into a aluminum transmission. Its holds a little but if it goes any tighter it slips. So what can i do? do i have to drop the transmission and tap the hole for a bigger bolt? heicoil?
Anyone had this happen before? how did u fix it?
Old Jan 16, 2010 | 12:48 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: torque arm problem
try to re tap it or heelicoil. if not get a trans crossmember that have the arm bolt to it.
Old Jan 16, 2010 | 12:57 AM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
I think i can get a helicoil or tap it, might get the tailshaft off tomorrow and see what i can do
Old Jan 16, 2010 | 04:21 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I don't think there are any bolts that thread in to the transmission, they just go through it, and have a nut on the other end.
Old Jan 16, 2010 | 06:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no, the trans mount bolts on into threaded holes, no nuts
Old Jan 16, 2010 | 07:27 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I think my has nuts and bolts, like gregs....I'll crawl under in a second and check.
But anyway, helicoil should work. Crossmember with torque arm mount would be even better. I know UMI performance has some. http://www.umiperformance.com/catalo...roducts_id=298
Old Jan 16, 2010 | 07:30 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I guess I didn't say what I meant very well, but yeah I know that. Isn't he talking about the torque arm mount, not the trans mount?
I guess it wouldn't make any sense for them to be talking about helicoils and taps if the problem was the TA mount though...
Old Jan 16, 2010 | 07:36 PM
Twin_Turbo's Avatar
If you mean the tranny mount, just drill oversize and tap it. Very common to see stripped threads there. If you're talking about the 3 long bolts for the torque arm mount itself, they are through bolts with nuts, there is no thread in the 3 bosses on the tailshaft.
Old Jan 16, 2010 | 08:13 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Ok the mount on the trans that the torque arm bushing sits in. Its bolted to the tranny fine. But the clamp that goes around the bushing and bolts to the tranny on the top of the mount is what im talking about. Its raining like hell so i cant get under and check it out. 91interceptor if u could take a look i would appreciate it so i know what i need to do when it stops raining.
But if there is supposed to be a long nut with a bolt i will get one and put it in tomorrow in the rain. But there was a shorter bolt that screwed in and got a little tight and seems to be holding for now, it was still in the bracket thats why i asked. But just let me know
Old Jan 16, 2010 | 08:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ok, the torque arm clambshell is held on with nuts and bolts.
Old Jan 16, 2010 | 08:22 PM
Twin_Turbo's Avatar
I think he means the 2 part clamp that the bushing itself is clamped in. It has a lip that falls into the parts that bolts to the tranny and has a small bolt up top that tightens it down, this goes into a welded on nut plate on the back of the other part.
This is the part as seen from the tranny side, this face bolts against the tailshaft. You can see the weld nut for the bolt
Old Jan 16, 2010 | 08:27 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
thats exactly what im talking about how can i fix it
Old Jan 16, 2010 | 08:34 PM
Twin_Turbo's Avatar
You'll have to lower the trans tailshaft (remove crossmember) to lower it so you can pull the 3 bolts off (if your exh is stock it hangs off this thing also) and remove it so you can work on it. Either grind off the nut and weld a new one on or drill and tap for a larger size. You could also try and use a slightly longer bolt and a nut on the back, you might be able to get that done without pulling it apart.
Old Jan 16, 2010 | 08:43 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
That doesnt sound to bad, i could probably take it to my old job and they will either let me use the welder or do it for like $10. Bad part is there closed on sundays lol
Old Jan 16, 2010 | 10:02 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
do i have to remove the torque arm to get that mount off or will i be able to get it around it? Will the transmission go low enough with the driveshaft still in or will i need to get it out to?
Old Jan 17, 2010 | 04:00 PM
Twin_Turbo's Avatar
Taking the tq arm off is no big deal, only 2 large bolts/nuts on the diff. The driveshaft won't have to come out.
Old Jan 17, 2010 | 04:01 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
alright well lets hope the bolt holds up until i can get a day off from work
Old Jan 18, 2010 | 07:28 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Ok it came loose again today so i got the bracket off, didn't have to drop the trans or remove the torque arm either so it took maybe 10 minutes. But mine doesn't have a nut welded to the back it screws into the trans case and there is no where for it to go through for a nut. So it has threads in the T5 case. I can do one of a few different things, first being a helicoil which would require me to drop the trans which i dont want to do. two other options would be to put the bolt through backwards and weld it to the bracket and just put a nut on the outside or weld a nut on the back like twin turbo said. But that would take away one of the mounting points for the bracket, it just has two other bolts that go all the way through plus it would move the bracket away from the trans at the top a little because of the bolt head. Would that work? would those two bolts be strong enough to hold it?
EDIT: also my bracket is different from yours twin turbo mine only has two bolts on the bottom that go all the way through
Old Jan 18, 2010 | 10:05 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I have trouble believing that, pics please...
Old Jan 18, 2010 | 11:19 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
uploading now to photobucket, dont have any pics from under the car just of the bracket
Old Jan 18, 2010 | 11:31 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
this is the side that the other piece of the clamshell goes into
This is the transmission side
Closer view of transmission side, my finger is on the hole that the i want to weld the bolt to that will make a stud for the clamshell. It has the one bolt made into the bracket, then another bolt that goes all the way through with a nut. But the top one threads into the trans, no way it could go all the way through unlesss they can run a bolt through the output shaft
Old Jan 19, 2010 | 07:16 AM
Twin_Turbo's Avatar
I didn't realize you have a T5, the one I posted is for an auto. Yes the T5 bracket is different and the top bolt goes into the tailshaft housing and the housing is threaded. If the thread is stripped you have to tap it oversize or use a nutsert (better than heli coil). You'll have to remove the transmission tailshaft or let the rear hang down low enough to be able to access it. I'm not even sure if you can let it hang that low. If need be you can remove the tail section from the main case with the tranny still in the car but you'll need to drive the rollpin for the shifter detent out from the top. Don't loose the spring and ball. The pin will not come out all the way, it only has to be driven down far enough to clear the shifter rail.
Maybe the easiest way is to get a tap and a small ratcheting box wrench small enough to be used on the square head of a thread tap and use that to tap out the hole 1 size bigger. The aluminum is real soft and may not need drilling. Possibly a metric size may be the best bet for a slightly larger size. With the tap and the ratcheting box end wrench you have a low profile setup that you may be able to wrestle in there with the tranny still in place. Another option is to epoxy in a stud but that's a little bubba for my taste.
Old Jan 19, 2010 | 12:32 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I didn't know that torque arms mounted differently to t5 than 700r4's...
Old Jan 19, 2010 | 08:48 PM
carzngirlz247's Avatar
Car: 1984 Camaro/1998 Integra GSR
Engine: 350zz4/GSR SC
Axle/Gears: 10 bolt-4.10 posi
I had the same problem with my t5, I drilled it out, tapped it bigger and has been fine for over 2k miles. I did drop the trans tho, just the gear box not the bell housing and all.
Old Jan 20, 2010 | 04:06 PM
BMR Sales's Avatar
Former Sponsor
Here is the easiest solution. We offer a torque arm relocation crossmember that will eliminate your problem plus save the tailshaft from breaking. This crossmember will also allow you to raise or lower the front of the torque which will effect your cars launching characteristics. If you have any questions please let me know.
http://www.bmrfabrication.com/F3-chassis.htm
Old Jan 22, 2010 | 01:56 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
You should be able to get the tailshaft low enough to access if you remove the 4 bolts holding up the crossmember, the only thing holding it up then will be the motor mounts and the rubber will flex enough to let the rear of the tranny drop. If you go the helicoil route or drill and tap that is
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
